Device goes offline periodically and then instantly gets back online
My device goes offline almost periodically at every 5 minutes only to instantly come back up. On opening the terminal on Host OS and running journalctl command these are a couple of series of logs I found unusual.
Jun 22 03:47:32 0982ed2 openvpn[6592]: ip: RTNETLINK answers: Operation not permitted
Jun 22 03:47:32 0982ed2 openvpn[6592]: Sat Jun 22 03:47:32 2019 Linux ip addr del failed: external program exited with error st>
Jun 22 03:47:33 0982ed2 openvpn[6592]: Sat Jun 22 03:47:33 2019 /etc/openvpn-misc/downscript.sh resin-vpn 1500 1555 10.240.1.98>
Jun 22 03:47:34 0982ed2 openvpn[6592]: Sat Jun 22 03:47:34 2019 ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlan0 HWADDR=b8:2>
Jun 22 03:47:34 0982ed2 openvpn[6592]: Sat Jun 22 03:47:34 2019 ERROR: Cannot ioctl TUNSETIFF resin-vpn: Operation not permitte>
Jun 22 03:47:34 0982ed2 openvpn[6592]: Sat Jun 22 03:47:34 2019 Exiting due to fatal error
Jun 22 03:47:34 0982ed2 systemd[1]: openvpn.service: Main process exited, code=exited, status=1/FAILURE
Jun 22 03:47:34 0982ed2 systemd[1]: openvpn.service: Failed with result 'exit-code'.
Jun 22 03:47:35 0982ed2 2d6bb95191f4[737]: [116B blob data]
and
Jun 22 07:16:07 0982ed2 kernel: Under-voltage detected! (0x00050005)
It would be nice if someone could help me out with this problem.
Hello @nishchayp .
Have you tried using a different power supply ? Under-voltage can cause hard to debug issues.
Hi @zvin, thanks for the reply.
Did change the power supply but the problem still persists. Please let me know if any other logs or command outputs might be helpful to figure this out.
Hey @nishchayp when you say the problem persists, do you mean only the vpn disconnections, or the undervoltage warnings too?
