Hello, can you please inspect the server logs for any hints? It looks to me like some of the backend containers aren’t running as they should. The command you need is ./scripts/compose exec -it SERVICE_NAME journalctl -fn1000. You’ll need to run this command once for each service, replacing SERVICE_NAME with api/registry/vpn/etc.
