Hey team,
I’ve been banging my head against this issue today. I just setup an openBalena instance (v0.1.2) according to the quickstart guide. I can login from my local machine and create applications successfully. I can also successfully deploy development images to the new application.
Upon spinning up a Raspberry Pi 3 with the application image flashed, I see the device gets registered but shows as offline. Looking at the device logs, I see a repeat of the following message:
Failed to download image 'registry.mydomain.io/v2/hash@sha256:hash' due to 'failed to register layer: Error processing tar file(exit status 1): unexpected EOF'
A quick google search seems to indicate that the above message relates to docker permissions. AFAIK, I’ve set up permissions according to the quickstart guide on client, server, and RPi.
I also see a smattering of this message in the logs:
Failed to download image 'registry.mydomain.io/v2/hash@sha256:hash' due to '(HTTP code 500) server error - Get https://registry.mydomain.io/v2/v2/hash/manifests/sha256:hash: received unexpected HTTP status: 503 Service Unavailable '
and this one:
Failed to download image 'registry.mydomain.io/v2/hash@sha256:hash' due to 'could not get decompression stream: Get https://registry.mydomain.io/v2/v2/hash/blobs/sha256:hash: read tcp x.x.x.x:33332->x.x.x.x:443: read: connection reset by peer'
curl’ing registry.mydomain.io gives me an empty 200 response.
Looking at the haproxy container logs, I see a series of messages showing that all the front and backends have been stopped, ending with
[WARNING] 354/223058 (1) : Server backend_api/resin_api_1 is DOWN, reason: Layer4 connection problem, info: "Connection refused", check duration: 0ms. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
[ALERT] 354/223058 (1) : backend 'backend_api' has no server available!
[WARNING] 354/223102 (1) : Server backend_api/resin_api_1 is UP, reason: Layer4 check passed, check duration: 0ms. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
I haven’t made any changes to the haproxy config provided in the open-balena repo, though it seems from the logs that haproxy might be a culprit? It also appears that my issue is separate from the other issue about devices not being online, though I could be wrong.
Is this a networking issue on my end? I, unfortunately, don’t have control over the network the RPi is on
Thanks for the great work! We’ve been looking forward to switching over to openBalena since the announcement
