Dev device showing splash screen
I am trying to access tty on the BalenaOS 2.72.0+rev1.dev Raspberry Pi 3 image; however, I am getting the balena splash screen instead of the tty. Is there a key command/settings I need to change for the tty to show up? I downloaded the image from balenaOS - Run Docker containers on embedded IoT devices and ran balena os configure .... --app MyApp on the image.
Hi Michael, the logo splash screen would normally be present on a Production image, that is for sure. But the Development images should indeed bring you to a login prompt. What happens if you try a Control-Alt-F2 or Control-Alt-F3, do you get a tty there by chance?
@dtischler when I hit Control-Alt-F2 I get a prompt! Thank you for your help.
Great news!
