Cross fade assets
I was trying to figure out a way to have assests/images cross fade while displaying instead of them doing a hard cut from image to image? So that way it has more of a smooth transition from image to image instead of the hard cut. I couldn’t really find any type of variable command that would allow me to do so. Need help if any possible.
Hi there @tbctech –
Would you mind elaborating a little bit on what you are trying to do here? Is there a project or demo that you are following that you can point us to?
Thank you!
Was wondering if there was a way to have the images cross fade one another instead of a hard cut from image to image. I’m creating a custom image for a customer that I can’t release due to privacy reasons. I showed them the mockup of what I had put together for them and they asked if I could make the images fade from one to another. Very similar to what a picture slide show would be created on a mac or windows pc, how each picture/image fades from and to each other. I hope this makes since
Hi again @tbctech!
It depends largely on what programming language and libraries you are using to control the images from the device, would you mind sharing how you have displayed the images?
