I’m sure this is available in the documentation but I simply cannot find it.
I am trying to access a RPI3 with an essentials container via a serial cable. The setup and connection is fine but I simply cannot find the credentials anywhere. What are the username and password?
Some more digging revealed the quite obvious answer.
user: root
password:
Glad you figured it out!
If the device is connected to the network, you can also use resin local ssh to drop you in directly: https://docs.resin.io/reference/cli/#local-ssh-deviceip-
Also note this only works on development resinOS images, and login is disabled on production images.
