copy fleets variables
How can I copy or move variables from fleets to another fleets in the same organization?
Firat
Hello @Firat
i’m not sure this is possible in an easy way. However i found this suggestion using a script on balena cli. Did you see this?
Hello @mpous
thank you for your answer, I will try to make another script that loops on the fleet variables and copies them to another fleet.
To be continued…
Keep us updated @Firat :slight_smile:
good news @mpous :grinning:
I developed a solution, available on my gitHub : GitHub - MiroYld/balena-copy-envs: copy your environment variables from fleet a to fleet b
Firat
This is awesome @Firat
Thank you for sharing!
Let us know how we can help you more :slight_smile:
What would be interesting would be to deploy this functionality on the balena interface, I would also like the balena cli to allow us to copy a variable to a fleet for a specific service and for a specific device
Hi there,
We now have a site here: https://roadmap.balena.io/ that will allow you to suggest this improvement - we are using this site to monitor demand for features from our users - others who like your suggestion may upvote it, and it is recorded somewhere. I’d suggest that you share your idea here as its a good one!
@Firat supporting the updated balena cli support values with spaces on new balena cli by MelleKoning · Pull Request #3 · MiroYld/balena-copy-envs · GitHub
@Melle
Thanks for the contribution ! :tada:
Both updates:
  • New balena env list command support :white_check_mark:
  • Config values with spaces handling :white_check_mark:
Merged!
