The “Failed to attach 1 to compat systemd cgroup” is reported when rebooting a container by use of console command ‘reboot’. The error output looks like this:
27.08.19 12:37:52 (+0200) main Failed to attach 1 to compat systemd cgroup /docker/2b4d221cf062a04b2d2bb85dd636c7a337f8e5c748d8b91f61da1a6835b92f28/init.scope: No such file or directory
27.08.19 12:37:52 (+0200) main Failed to open pin file: No such file or directory
27.08.19 12:37:52 (+0200) main Failed to allocate manager object: No such file or directory
27.08.19 12:37:52 (+0200) main [!!!] Failed to allocate manager object, freezing.
If the device is rebooted by use of the ‘Restart’ button in the balena dashboard, then the container is started correctly and everything works as expected. Performing the console ‘reboot’ command will freeze the container again.
One major changes has been migration from resin/intel-nuc-debian:stretch to resin/intel-nuc-ubuntu:bionic. Unsure if this is related.
Any guide how to solve this?
Device is running: balenaOS 2.39.0+rev3, supervisor 10.0.3
@aliasbits there isn’t really much to go on here. Restarting the container doesn’t reboot the device, so it could be that whatever your container is doing on startup is preparing something, which then is accessible after a container restart.
Could you explain a bit more about what your container is doing/trying to do, and what your motivations to change from a debian base, to an ubuntu base were?
The change from debian to ubuntu was performed in order to align against internal development processes and to allow for the latest upstream version of some packages.
The application is working as expected on both. Some of the system changes in the entrypoint are:
Setup config files
Setup environment vars
Setup network
Setup preconditions before serviced service startup
Start various systemd services
Setup loopback filesystems on /dev/loop0 ( this has been disabled which does not make any difference )
Many of the changes are performed in a persistent balena volume.
I added a "echo ‘entrypoint’ " in the top of the entrypoint.sh script. ‘Entrypoint’ printout is show as expected on normal startup, but is missing when performing the console ‘reboot’. Hence, the entrypoint script is not executed after reboot. Please note that the image does not perform any docker/balena change to the system. Everything is setup by the docker compose file and the entrypoing script.
Without some indication of what that entrypoint script is doing, it’s very hard to say what the issue is. A container restart, and a reboot, are both synonymous from the containers perspective; the only thing which could be different is the host system.
As @richbayliss mentioned, without some insight into your entry script it’ll be difficult to assist. If you are so inclined, you can try updating to the balenalib base image set since systemd in the container has been known to cause issues. Do note the breaking changes listed here: https://www.balena.io/docs/reference/base-images/base-images/#major-changes.
If you do try this, please let us know how the test goes!
Technically the resin/ base images are deprecated. We don’t update the resin/ base images any more. We’d recommend moving to balenalib ones moving forward.
Another key thing is that any further OS releases, testing, fixes are done for balenalib images only.
We still need to reproduce and investigate where the following error is coming from Failed to attach 1 to compat systemd cgroup
I’ve been trying to reproduce the issue but have failed to do so.
Would it be possible to share your application in a zip file via a direct message? Trim out the bits that are unnecessary and leave just enough to reproduce this.
