I was wondering if there was a way to edit these Configuration List for Raspberry Pi 5 - Balena Documentation without SSHing in to the device directly and changing config.txt or doing it from the dashboard. Is there a way to do this from the config.json, or is there another different way to do this?
Thank you for your help!
- The
config.jsonfile is typically found in theresin-bootpartition of the SD card used by the Raspberry Pi. You can access this partition by inserting the SD card into your computer.
- The
- Edit the
config.jsonfile: - Open the
config.jsonfile using a text editor. You can add configuration settings to this file in JSON format. - Regards:
- Names haven
