i am not able to find much information, but i was wondering if you are able to use etcher to clone an hdd to a ssd. i am able to chose them to clone but didnt want to chance it if its not able to?
Hi @spartin153,
On the most recent versions of Etcher you shouldn’t have an issue cloning a hdd to a ssd so long as the target device is the same size or larger than your hdd. When you use etcher just make sure to click clone drive rather than the flash from file button.
This screenshot is from Etcher version 1.7.1 so I suggest updating if you haven’t in a while.
A file has been uploaded using Jellyfish: Jellyfish
Awesome thanks for your help!
I am using a SSD and its possible
