checksum does not match for range [0,534162367]:"d676aafb21d3dc5a != “32060b47b445c7a”
I got this error with more than 2 sd card, and more than 1 device. both were C10 SD 32GB.
Any possible solution to this error?
Hello, Do you have more than one SD card reader? I’d recommend trying a different reader, and see if you have the same result. There may also be more information from etcher in the dev console, which you can open with ctrl + shift + i .
yes, the first I tried was a usb converter for sd cards. later I used a laptop with a sd card reader. I will check what you said about more info I am giving it one more try.
