Cant run Balena Etcher on MACOSX 10.7.5 (Lion)
Hi
The FAQs for Etcher say
Etcher GUI is based on the Electron framework, which only supports macOS 10.10 and newer versions.
but when I try to run it on an old Pismo running Lion 10.7.5, it says ‘The application requires Mac Os X 11.0 or later’.
Is the FAQ out of date and, if so, is there somewhere I can download an older version of Balena Etcher?
I just realised that it’s been too long since I worked on an old Mac - 10.10 does not equal 10.1, does it? :slight_smile: So a higher version than 10.7.5…
Anyone know of any other product similar to Etcher than will work on 10.7.5 (the highest macos I can install on this old machine)?
