Good morning,
I have been trying to download the zip file for “Fold for Covid” for two days. The software download for Generic AARCH64 (ARMv8) does not start…
Sorry for been late. In case you use Generic AARCH64 (ARMv8) you only have a configuration file so you must create a new Balena account following this steps:
https://forums.balena.io/t/cant-login-to-my-account/95331/7?u=manuti
And you must have a complete operative system installed on your board and also install docker and balenaOS in container GitHub - balena-os/balenaos-in-container: Run balenaOS as a docker container.
After that you can run a Generic AARCH64 instance using a command like this:
./balenaos-in-container.sh --config ./Your-Donwload.config.json --image resin/resinos:2.12.4_rev1-generic-aarch64
