Can't connect to devices with VPN SSH
I finished to work on my apps for rpi4 and rpi3.
I now need to secure and make reliable this configuration.
I will need to deploy some device remotely so I absolutely need to make the VPN work.
I’ve been struggling with the remote SSH via VPN since few days…
I searched a lot from the forums, from the github issues, from the documentation and I tried pretty much everything I found and I can’t still make it work.
Here is my config from OpenBalena:
  • OpenBalena 2.0.3
  • OPENBALENA_API_VERSION_TAG=v0.19.5
  • OPENBALENA_DB_VERSION_TAG=v2.0.3
  • OPENBALENA_MDNS_PUBLISHER_VERSION_TAG=v1.6.2
  • OPENBALENA_REGISTRY_VERSION_TAG=v2.11.1
  • OPENBALENA_S3_VERSION_TAG=v2.8.5
  • OPENBALENA_VPN_VERSION_TAG=v8.10.0
I’m using the BalenaCLI v12.3.3.
For Rpi4 I use the BalenaOS v2.48.0 dev
For Rpi3 I use the BalenaOS v2.47.0 dev
Here is each tasks I do to enable the SSH VPN (I use Mac) :
  1. balena os configure balena.img --app MyApp
  2. mount the image with the GUI Mac DiskImageMounter
  3. open the config.json file and add at the end (one-line) : "os":{"sshKeys":["ssh-rsa blablablaC8CM= me@MacBook.home"]} (I validated the json structure with https://jsonformatter.curiousconcept.com)
  4. flash the image to the SD card
  5. booting the device
I can see the device from the command balena devices with “IS ONLINE : true”
balena devices
    ID UUID    DEVICE NAME      DEVICE TYPE     APPLICATION NAME       STATUS IS ONLINE SUPERVISOR VERSION OS VERSION           DASHBOARD URL
    36 7c734c9 morning-tree     raspberrypi3-64 MyAppNamexxxxxxxxxxxxx Idle   true      10.6.27            balenaOS 2.47.0+rev1
When I try :
  • balena ssh 7c734c9
  • balena ssh LongUUID (obtained by balena device 7c734c9
  • balena ssh 7c734c9 ServiceName
I have always the message root@[ssh.devices.openbalena.mydomain.com](http://ssh.devices.openbalena.asappli.com/)'s password:
When I do:
  • curl https://api.mydomain/ping I have an “OK” response.
  • curl https://vpn.mydomain/ping I have an “200 OK. Service ready” response.
Is the VPN SSH only possible with production version ?
Do I miss something into the SSH add key process ?
Thanks for your help :slight_smile:
Hi, can you try the steps provided in this blog post?
I tried before and I certainly missed something.
Now it’s working perfectly! thanks @karaxuna :slight_smile:
