Cannot connect to WIFI Balena Sound raspberry pi 3
I used the same button too. Is there any new update?
I deployed it 4 days ago.
Hello Jose, Please could you describe the problem you are having (It might be best to do this in a new thread as it seems there are multiple issues already on this one).
I deployed it on Saturday, November 14 and it worked. I am not sure if it has a new update. Best of luck.
Hi guys,
I have a similar problem. I have flashed the SD card for a RPI 3B and for RPI 4 with all latest options chosen from the Balena cloud and used balenaEtcher. I have selected Ethernet+Wifi but I have plugged a eth cable to be safe for now. Everytime I startup the device it just does this
01.07.21 16:50:10 (+0200) Supervisor starting
01.07.21 16:50:13 (+0200) Applying configuration change {"SUPERVISOR_POLL_INTERVAL":"900000","SUPERVISOR_DELTA":"1","SUPERVISOR_DELTA_VERSION":"3"}
01.07.21 16:50:13 (+0200) Applied configuration change {"SUPERVISOR_POLL_INTERVAL":"900000","SUPERVISOR_DELTA":"1","SUPERVISOR_DELTA_VERSION":"3"}
01.07.21 16:50:13 (+0200) Creating network 'default'
The status is ā€œOnlineā€ but it seems like no container/service is loaded for any connection and I cannot find it via bluetooth, Airplay or Spotify … Please help!
I am inside my company (guest) network and there shouldn’t be any port restrictions etc.
Could this still be an issue?
Hi there, could you confirm that your application has a balena sound release pushed to it? Releases can be seen by clicking on ā€œreleasesā€ on the right hand side of the dashboard, when looking at the application view
I just have found this post: balenaSound no services on raspberry pi 3b - #5 by alanb128
You are right, I some how missed to get a release on the OS as I thought the OS would install it by itself :slight_smile:
All services seem up and running, I can find the device in bluetooth and also in Spotify BUT when trying to connect in Spotify it just says "connecting … " and in the log is:
01.07.21 17:22:15 (+0200) spotify [2021-07-01T15:22:15Z INFO librespot_core::session] Connecting to AP "gew1-accesspoint-a-dv19.ap.spotify.com:4070"
UPDATE: I gotta configure credentials lol I should just start reading the whole doc. What if I am using as my Spotify login my Facebook ā€œeasy loginā€? Should I use my Facebook credentials then?
Hi there, nice one! Almost there, let us know how it goes, or if you have any more questions :slight_smile:
thats a good question, I’m actually not sure - did you try it? I’m not familiar with the facebook login option, but is it a total replacement for the password on spotify? I’ll ask the team about it
I did find my Spotify username by checking my account through www.spotify.com. The username is a longer number. I also reseted my password so I am sure to have the valid password. Unfortunately I still cannot play music through Spotify. I get this log but cannot find the device in Spotify:
01.07.21 17:20:26 (+0200)  spotify  Starting Spotify plugin...
01.07.21 17:20:26 (+0200)  spotify  Device name: balenaSound Spotify c272
01.07.21 17:20:26 (+0200)  spotify  Using provided credentials for Spotify login.
01.07.21 17:20:26 (+0200)  spotify  Volume normalization enabled.
01.07.21 17:20:26 (+0200)  spotify  Spotify audio cache disabled.
01.07.21 17:20:26 (+0200)  spotify  [2021-07-01T15:20:26Z INFO  librespot] librespot (raspotify v0.16.0) 0adb851 (2020-12-15). Built on 2020-12-30. Build ID: KLdkAvgt
01.07.21 17:20:26 (+0200)  spotify  [2021-07-01T15:20:26Z INFO  librespot_core::session] Connecting to AP "gew1-accesspoint-a-mr5t.ap.spotify.com:4070"
After a couple of minutes I also got:
01.07.21 17:22:37 (+0200) spotify [2021-07-01T15:22:37Z ERROR librespot] Could not connect to server: Connection timed out (os error 110)
Is that error happening consistently, even after reboots etc? I’m not familiar with the error message, but it looks like there’s some issue connecting. What sort of network setup do you have with the device?
I re-read a bit of this one, and you said you are on a corporate network. I wonder if it’s being firewalled / filtered. You’ll need to be able to resolve that domain name in question: "gew1-accesspoint-a-mr5t.ap.spotify.com:4070"
