Cannot access Pins in Raspberry pi 5
I’ve been working on a project that involves controlling GPIO pins on a Raspberry Pi using Balena. I successfully managed to get it working on a Raspberry Pi 4 following the guidelines provided in this document.
However, when I try to run the same setup on a Raspberry Pi 5, it doesn’t seem to work. Here are the details:
  1. Setup on Raspberry Pi 4:
  • Followed the Balena documentation for GPIO access.
  • Used Python with the gpiozero library.
  • Everything worked as expected.
  1. Attempt on Raspberry Pi 5:
  • Followed the same steps as for the Raspberry Pi 4.
  • Used Python with the gpiozero library, which is supposed to support Raspberry Pi 5.
  • Encountered the following errors:
PinFactoryFallback: Falling back from lgpio: No module named 'lgpio'
  warnings.warn(
Traceback (most recent call last):
  File "/workspace/demo-led/venv/lib/python3.11/site-packages/gpiozero/pins/pi.py", line 411, in pin
    pin = self.pins[info]
KeyError: PinInfo(number=37, name='GPIO26', names=frozenset({'WPI25', 'GPIO26', '26', 'BCM26', 'BOARD37', 26, 'J8:37'}), pull='', row=19, col=1, interfaces=frozenset({'', 'sdio', 'spi', 'gpio', 'jtag', 'dpi'}))
During handling of the above exception, another exception occurred:
  File "/workspace/demo-led/led.py", line 10, in <module>
    led = RGBLED(R_GPIO, G_GPIO, B_GPIO)
  File "/workspace/demo-led/venv/lib/python3.11/site-packages/gpiozero/devices.py", line 108, in __call__
    self = super().__call__(*args, **kwargs)
  File "/workspace/demo-led/venv/lib/python3.11/site-packages/gpiozero/output_devices.py", line 877, in __init__
    self._leds = tuple(
  File "/workspace/demo-led/venv/lib/python3.11/site-packages/gpiozero/output_devices.py", line 878, in <genexpr>
    LEDClass(pin, active_high=active_high, pin_factory=pin_factory)
  File "/workspace/demo-led/venv/lib/python3.11/site-packages/gpiozero/output_devices.py", line 392, in __init__
    super().__init__(pin, active_high=active_high, initial_value=None,
  File "/workspace/demo-led/venv/lib/python3.11/site-packages/gpiozero/output_devices.py", line 74, in __init__
    super().__init__(pin, pin_factory=pin_factory)
  File "/workspace/demo-led/venv/lib/python3.11/site-packages/gpiozero/mixins.py", line 75, in __init__
    super().__init__(*args, **kwargs)
  File "/workspace/demo-led/venv/lib/python3.11/site-packages/gpiozero/devices.py", line 553, in __init__
    pin = self.pin_factory.pin(pin)
  File "/workspace/demo-led/venv/lib/python3.11/site-packages/gpiozero/pins/pi.py", line 413, in pin
    pin = self.pin_class(self, info)
  File "/workspace/demo-led/venv/lib/python3.11/site-packages/gpiozero/pins/rpigpio.py", line 101, in __init__
    GPIO.setup(self._number, GPIO.IN, self.GPIO_PULL_UPS[self._pull])
RuntimeError: Cannot determine SOC peripheral base address
  • Additionally, when I try to manually export a GPIO pin with echo 26 > /sys/class/gpio/export as mentioned in the documentation, I get:
bash: echo: write error: Invalid argument
I’m looking for guidance on the following points:
  • Is GPIO access enabled by default for the Raspberry Pi 5 on Balena OS?
  • Are there any additional steps or configurations needed specifically for the Raspberry Pi 5 to enable GPIO access?
  • Is there support for lgpio or an equivalent library that works seamlessly with gpiozero on the Raspberry Pi 5?
Any insights or suggestions to resolve this issue would be greatly appreciated. Thank you for your assistance!
Hello @fredhii, I have used the GPIO on the Pi 5 with balena, so it is possible.
You can see an example that worked for me here: pi-digital-signage-demo/signage at master · alanb128/pi-digital-signage-demo · GitHub . Note the installation method of lgpio in the Dockerfile.template and the use of the library in the signage.py script.
