I’m trying to run a simple script using the RaspberryPi’s GPIO input.
app.py
from gpiozero import Button
def main():
button = Button(17)
button.when_pressed = on_button_press
button.when_released = on_button_release
def on_button_press():
print("button 17 pressed!")
def on_button_release():
print("button 17 released...")
if __name__ == "__main__":
main()
Dockerfile.template
FROM balenalib/raspberrypi4-64-debian-python:3.11-bullseye-build
WORKDIR /app
RUN pip install RPi.GPIO gpiozero
COPY . .
CMD ["python3", "app.py"]
docker-compose.yml
version: "2"
services:
app:
build: .
environment:
- GPIOZERO_PIN_FACTORY=RPiGPIO
privileged: true
restart: always
I’d really like to be able to use the gpiozero library as I find it much easier to use than RPi.GPIO. However, it seems as though there’s some sort of issue with accessing GPIO factories as when running, I initially got this error:
[app] /usr/lib/python3/dist-packages/gpiozero/devices.py:288: PinFactoryFallback: Falling back from rpigpio: No module named ‘RPi’
[app] warnings.warn(
[app] /usr/lib/python3/dist-packages/gpiozero/devices.py:288: PinFactoryFallback: Falling back from lgpio: No module named ‘lgpio’
[app] /usr/lib/python3/dist-packages/gpiozero/devices.py:288: PinFactoryFallback: Falling back from rpio: No module named ‘RPIO’
[app] /usr/lib/python3/dist-packages/gpiozero/devices.py:288: PinFactoryFallback: Falling back from pigpio: No module named ‘pigpio’
[app] /usr/lib/python3/dist-packages/gpiozero/devices.py:285: NativePinFactoryFallback: Falling back to the experimental pin factory NativeFactory because no other pin factory could be loaded. For best results, install RPi.GPIO or pigpio. See 23. API - Pins — GPIO Zero 1.6.2 Documentation for more information.
[app] warnings.warn(NativePinFactoryFallback(native_fallback_message))
This error happens even with RPi.GPIO installed.
When manually setting gpiozero to use RPi.GPIO as its factory using the GPIOZERO_PIN_FACTORY=RPi.GPIO env variable, I get this error;
gpiozero.exc.BadPinFactory: Unable to find pin factory “RPi.GPIO”
As far as I can tell, this is either a Docker or BalenaOS issue as I’ve not had this problem when running gpiozero natively on Raspberry Pi OS.
Changing the code to use the RPi.GPIO library directly works fine. Given the simple syntax of gpiozero though I’d love the option of using it.
Any help would be much appreciated.
