Question
I am trying to access the GPIO pins using the Python module gpiozero, from within a container.
gpiozero can work with several low level libraries - or pin factories.
I tried several, and the all give problems related to permissions.
Maybe this has to to with running from inside a container?
Who can help?
I am using a raspberry pi zero.
Setup to reproduce error
Let me show you what happens if I use the RPI-Gpio library as backbend. The same library is used in the example repo balena-rpi-gpio-sample-with-python .
Dockerfile.template looks like this:
FROM balenalib/%%BALENA_MACHINE_NAME%%-python:3.11.2-run
RUN apt update -y; apt upgrade -y
RUN apt -y install build-essential
RUN pip install rpi-gpio==0.7.1 gpiozero==1.6.2
ENV GPIOZERO_PIN_FACTORY=rpigpio
docker-compose.yml
version: "2"
services:
irrigation:
build: .
ports:
- "80:8000"
Then in the docker container I execute the following python script (I use the interactive interpreter)
from gpiozero import OutputDevice
v = OutputDevice(23)
Error
It gives the following error:
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.11/site-packages/gpiozero/devices.py", line 108, in __call__
self = super(GPIOMeta, cls).__call__(*args, **kwargs)
File "/usr/local/lib/python3.11/site-packages/gpiozero/output_devices.py", line 83, in __init__
super(OutputDevice, self).__init__(pin, pin_factory=pin_factory)
File "/usr/local/lib/python3.11/site-packages/gpiozero/mixins.py", line 85, in __init__
super(SourceMixin, self).__init__(*args, **kwargs)
File "/usr/local/lib/python3.11/site-packages/gpiozero/devices.py", line 549, in __init__
pin = self.pin_factory.pin(pin)
File "/usr/local/lib/python3.11/site-packages/gpiozero/pins/pi.py", line 103, in pin
pin = self.pin_class(self, n)
File "/usr/local/lib/python3.11/site-packages/gpiozero/pins/rpigpio.py", line 111, in __init__
GPIO.setup(self.number, GPIO.IN, self.GPIO_PULL_UPS[self._pull])
RuntimeError: No access to /dev/mem. Try running as root!
Within the container I am root:
>>> root@3833176168f5:/# whoami
root
Follow Python gpio example to produce same error
Follwoing the script in the Python gpio example closely, I get the same error
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.output(23, 1)
