I was wondering how much the Bluetooth range is of raspberry pi 3B+ for multi room can I play audio from my living room to the device in the basement.
Hi Umar, with the multi-room all the follower nodes will be communicating with the central/server node via wifi/ethernet so there shouldn’t be a range issue there. So the only range issue would be from your phone/laptop to the central/server node which I think would be pretty standard bluetooth range, something like 10 meters indoor. So if you and the central node are in you living room together and then you have a follower node in the basement that should all work fine.
