I’m not sure whether we’ve tested this device with balenaOS. I’ve asked our team to see if anyone has used one. Other than that I can only give you the general advice that if it works with Raspbian it can be made to work with balenaOS with varying degrees of messing around required to make it work. Doing some googling seems to indicate that the device relies on quite a new raspberry pi firmware version, which AFAICT we haven’t shipped yet in our production images (I am not a member of the balenaOS team though, so I can’t be sure). I don’t want to say it can’t be done, but I also don’t want to underestimate how annoying troubleshooting cellular connections can be. I’ll let you know if one of the team pipes up and says they’ve used one before.
Hi, adding to what my colleague said, here is the list of the modems we currently test our OS with: https://github.com/balena-os/meta-balena#modems
This is not to say that the Quectel BG96 won’t work with balenaOS, we just have not tested it. I would be interested in knowing if it works as expected if you have the hw to give it a go.
Thanks both for the insight! I may give it a go and will report back on the BG96. Is there much difference between the base BalenaFin image/firmware and a RaspberryPi image?
Hey @kylixz,
Could you please provide us the entire ModemManager debug logs, so that we can assist you further?
What you could do is open a terminal session, stop the ModemManager service with systemctl and then run manually ModemManager, e.g. ModemManager --debug 2>&1 | tee /mnt/data/mm-logs-01.txt. After this, you could grab the file with a service like file.io or transfer.sh and share this file with us here.
Hi @kylixz, I cannot download the file - I think it is only allowed to be downloaded once. Can you please attach it here through the Upload chat button?
Zahari
Hey @kylixz, I wanted to check if you managed to proceed with the modem?
Unfortunately, we didn’t manage to download the logs you shared with us. Please let us know if you need any further help.
