Since the Beagebone black uses “Burn SD data to eMMC then remove SD” provisioning, is it necessary to burn an SD card for each BBB I need to provision, or can I use, for example, a single SD, flash it once with Etcher, and use it to provision 4 BBBs?
Hi @jhardy1 for the Beaglebone Black you can use a single SD device to provision as many devices as you would like!
