balenaSense v2.0.0 services not starting
Hi All,
I have deployed the latest balenaSense v2.0.0 which seems to have went OK, however after completion it fails to start influxdb/senssor/connector services.
I have attached the default log from the balena device logging as well as the balena CLI build below.
Maybe its still too early to test, otherwise I’m happy to allow access to the device and/or provide any information required.
air-quality-monitor_small-water-17.05.21_18_48_12_(+0100).txt (150.6 KB)
[Info]       Starting build for air-quality-monitor, user lewisg743
[Info]       Dashboard link: https://dashboard.balena-cloud.com/apps/1825227/devices
[connector]  [=========================================================] 100%
[sensor]     [=========================================================] 100%
[dashboard]  [=========================================================] 100%
[Info]       Uploading images
[Success]    Successfully uploaded images
[Info]       Built on arm03
[Success]    Release successfully created!
[Info]       Release: 5dbf13cfe498f20302b696c3f43e7c77 (id: 1801649)
[Info]       ┌───────────┬────────────┬────────────┐
[Info]       │ Service   │ Image Size │ Build Time │
[Info]       ├───────────┼────────────┼────────────┤
[Info]       │ influxdb  │ 252.34 MB  │ 45 seconds │
[Info]       │ dashboard │ 213.31 MB  │ 43 seconds │
[Info]       │ sensor    │ 270.23 MB  │ 46 seconds │
[Info]       │ connector │ 278.84 MB  │ 1 minute,  │
[Info]       └───────────┴────────────┴────────────┘
[Info]       Build finished in 2 minutes, 10 seconds
Hey @alanb128 can you figure out what’s wrong here?
Hello, thanks for the report. What device type are you using?
Hey mate, Pi Zero WH + BME680 Breakout + Breakout Garden
BalenaSense 2 is currently only supported on the Pi2/3/4 (ARMv7 and aarch64) so that accounts for the errors you’re seeing using the Pi Zero. Two of the blocks used in version 2 of balenaSense do not have an ARMv6 version, and neither does InfluxDB. I created an issue for this in GitHub and there will be an update posted here when it’s closed out. Support for Pi Zero? · Issue #103 · balenalabs/balena-sense · GitHub
Thanks for the update, ill need to grab something else for the time being in that case.
