Logs attached
17.10.21 22:09:01 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
17.10.21 22:09:01 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
17.10.21 22:09:02 (+0100) Waiting for Influx API
18.10.21 10:20:02 (+0100) Supervisor starting
18.10.21 10:16:47 (+0100) 1634548607: mosquitto version 1.6.15 starting
18.10.21 10:16:47 (+0100) 1634548607: Config loaded from /mosquitto/config/mosquitto.conf.
18.10.21 10:16:47 (+0100) 1634548607: Opening ipv4 listen socket on port 1883.
18.10.21 10:16:47 (+0100) 1634548607: Opening ipv6 listen socket on port 1883.
18.10.21 10:16:47 (+0100) 1634548607: mosquitto version 1.6.15 running
18.10.21 10:17:16 (+0100) 1634548635: mosquitto version 1.6.15 terminating
18.10.21 10:18:12 (+0100) 1634548692: mosquitto version 1.6.15 starting
18.10.21 10:18:12 (+0100) 1634548692: Config loaded from /mosquitto/config/mosquitto.conf.
18.10.21 10:18:12 (+0100) 1634548692: Opening ipv4 listen socket on port 1883.
18.10.21 10:18:12 (+0100) 1634548692: Opening ipv6 listen socket on port 1883.
18.10.21 10:18:12 (+0100) 1634548692: mosquitto version 1.6.15 running
18.10.21 10:16:52 (+0100) balenaBlocks dashboard version: 1.1.3
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] Starting Grafana logger=server version=7.1.3 commit=5723d951af branch=HEAD compiled=2020-08-06T08:44:32+0000
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] Config loaded from logger=settings file=/usr/share/grafana/conf/defaults.ini
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] Config overridden from Environment variable logger=settings var=“GF_PATHS_DATA=/data/dashboard”
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] Config overridden from Environment variable logger=settings var=“GF_SERVER_HTTP_PORT=80”
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] Config overridden from Environment variable logger=settings var=“GF_AUTH_ANONYMOUS_ENABLED=true”
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] Path Home logger=settings path=/usr/share/grafana
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] Path Data logger=settings path=/data/dashboard
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] Path Logs logger=settings path=/usr/share/grafana/data/log
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] Path Plugins logger=settings path=/usr/share/grafana/data/plugins
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] Path Provisioning logger=settings path=/usr/share/grafana/conf/provisioning
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] App mode production logger=settings
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] Connecting to DB logger=sqlstore dbtype=sqlite3
18.10.21 10:17:01 (+0100) INFO[10-18|09:17:01] Starting DB migration logger=migrator
18.10.21 10:17:02 (+0100) Starting dashboard sync, checking APIs…
18.10.21 10:17:03 (+0100) INFO[10-18|09:17:03] Starting plugin search logger=plugins
18.10.21 10:17:03 (+0100) Waiting for Grafana API
18.10.21 10:17:06 (+0100) INFO[10-18|09:17:06] Registering plugin logger=plugins name=“Direct Input”
18.10.21 10:17:08 (+0100) Waiting for Grafana API
18.10.21 10:17:13 (+0100) Waiting for Grafana API
18.10.21 10:17:26 (+0100) Waiting for Grafana API
18.10.21 10:17:26 (+0100) INFO[10-18|09:17:20] HTTP Server Listen logger=http.server address=[::]:80 protocol=http subUrl= socket=
18.10.21 10:17:26 (+0100) Waiting for Influx API
18.10.21 10:17:28 (+0100) Waiting for Influx API
18.10.21 10:17:31 (+0100) INFO[10-18|09:17:31] Shutdown started logger=server reason=“System signal: terminated”
18.10.21 10:17:31 (+0100) INFO[10-18|09:17:31] Stopped Stream Manager
18.10.21 10:18:58 (+0100) balenaBlocks dashboard version: 1.1.3
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] Starting Grafana logger=server version=7.1.3 commit=5723d951af branch=HEAD compiled=2020-08-06T08:44:32+0000
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] Config loaded from logger=settings file=/usr/share/grafana/conf/defaults.ini
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] Config overridden from Environment variable logger=settings var=“GF_PATHS_DATA=/data/dashboard”
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] Config overridden from Environment variable logger=settings var=“GF_SERVER_HTTP_PORT=80”
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] Config overridden from Environment variable logger=settings var=“GF_AUTH_ANONYMOUS_ENABLED=true”
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] Path Home logger=settings path=/usr/share/grafana
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] Path Data logger=settings path=/data/dashboard
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] Path Logs logger=settings path=/usr/share/grafana/data/log
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] Path Plugins logger=settings path=/usr/share/grafana/data/plugins
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] Path Provisioning logger=settings path=/usr/share/grafana/conf/provisioning
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] App mode production logger=settings
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] Connecting to DB logger=sqlstore dbtype=sqlite3
18.10.21 10:19:00 (+0100) INFO[10-18|09:19:00] Starting DB migration logger=migrator
18.10.21 10:19:02 (+0100) INFO[10-18|09:19:02] Starting plugin search logger=plugins
18.10.21 10:19:07 (+0100) INFO[10-18|09:19:07] Registering plugin logger=plugins name=“Direct Input”
18.10.21 10:19:07 (+0100) Starting dashboard sync, checking APIs…
18.10.21 10:19:07 (+0100) Waiting for Grafana API
18.10.21 10:19:12 (+0100) Waiting for Grafana API
18.10.21 10:19:17 (+0100) INFO[10-18|09:19:17] HTTP Server Listen logger=http.server address=[::]:80 protocol=http subUrl= socket=
18.10.21 10:19:18 (+0100) Waiting for Influx API
18.10.21 10:19:23 (+0100) Waiting for Influx API
18.10.21 10:19:28 (+0100) Waiting for Influx API
18.10.21 10:19:33 (+0100) Waiting for Influx API
18.10.21 10:19:38 (+0100) Waiting for Influx API
18.10.21 10:19:43 (+0100) Waiting for Influx API
18.10.21 10:19:48 (+0100) Waiting for Influx API
18.10.21 10:19:53 (+0100) Waiting for Influx API
18.10.21 10:19:58 (+0100) Waiting for Influx API
18.10.21 10:20:03 (+0100) Waiting for Influx API
18.10.21 10:20:11 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:20:13 (+0100) Waiting for Influx API
18.10.21 10:20:18 (+0100) Waiting for Influx API
18.10.21 10:20:23 (+0100) Waiting for Influx API
18.10.21 10:20:27 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:20:28 (+0100) Waiting for Influx API
18.10.21 10:20:34 (+0100) Waiting for Influx API
18.10.21 10:20:35 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:20:39 (+0100) Waiting for Influx API
18.10.21 10:20:44 (+0100) Waiting for Influx API
18.10.21 10:20:47 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:20:49 (+0100) Waiting for Influx API
18.10.21 10:20:54 (+0100) Waiting for Influx API
18.10.21 10:20:56 (+0100) Starting service ‘influxdb sha256:5426da1fe5416ab2ec19ea8598054c840af9e41a56b877c94bcb533e54abf675’
18.10.21 10:20:56 (+0100) Starting service ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:21:02 (+0100) Waiting for Influx API
18.10.21 10:21:07 (+0100) Waiting for Influx API
18.10.21 10:21:12 (+0100) Waiting for Influx API
18.10.21 10:21:17 (+0100) Waiting for Influx API
18.10.21 10:21:20 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:21:20 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:21:22 (+0100) Waiting for Influx API
18.10.21 10:21:25 (+0100) Started service ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:21:27 (+0100) Waiting for Influx API
18.10.21 10:21:32 (+0100) Waiting for Influx API
18.10.21 10:21:37 (+0100) Waiting for Influx API
18.10.21 10:21:40 (+0100) Service exited ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:21:42 (+0100) Waiting for Influx API
18.10.21 10:21:47 (+0100) Waiting for Influx API
18.10.21 10:21:52 (+0100) Waiting for Influx API
18.10.21 10:21:57 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:21:57 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:21:57 (+0100) Waiting for Influx API
18.10.21 10:22:02 (+0100) Waiting for Influx API
18.10.21 10:22:05 (+0100) Restarting service ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:22:07 (+0100) Waiting for Influx API
18.10.21 10:22:09 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:22:10 (+0100) Starting service ‘influxdb sha256:5426da1fe5416ab2ec19ea8598054c840af9e41a56b877c94bcb533e54abf675’
18.10.21 10:22:16 (+0100) Waiting for Influx API
18.10.21 10:22:22 (+0100) Service exited ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:22:21 (+0100) Waiting for Influx API
18.10.21 10:22:26 (+0100) Waiting for Influx API
18.10.21 10:22:31 (+0100) Waiting for Influx API
18.10.21 10:22:35 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:22:36 (+0100) Waiting for Influx API
18.10.21 10:22:41 (+0100) Waiting for Influx API
18.10.21 10:22:46 (+0100) Waiting for Influx API
18.10.21 10:22:48 (+0100) Restarting service ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:22:49 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:22:51 (+0100) Waiting for Influx API
18.10.21 10:22:56 (+0100) Waiting for Influx API
18.10.21 10:23:01 (+0100) Waiting for Influx API
18.10.21 10:23:06 (+0100) Service exited ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:23:06 (+0100) Waiting for Influx API
18.10.21 10:23:12 (+0100) Waiting for Influx API
18.10.21 10:23:17 (+0100) Waiting for Influx API
18.10.21 10:23:22 (+0100) Waiting for Influx API
18.10.21 10:23:25 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:23:25 (+0100) Starting service ‘influxdb sha256:5426da1fe5416ab2ec19ea8598054c840af9e41a56b877c94bcb533e54abf675’
18.10.21 10:23:30 (+0100) Waiting for Influx API
18.10.21 10:23:35 (+0100) Waiting for Influx API
18.10.21 10:23:40 (+0100) Waiting for Influx API
18.10.21 10:23:45 (+0100) Waiting for Influx API
18.10.21 10:23:49 (+0100) Restarting service ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:23:50 (+0100) Waiting for Influx API
18.10.21 10:23:55 (+0100) Waiting for Influx API
18.10.21 10:24:00 (+0100) Waiting for Influx API
18.10.21 10:24:02 (+0100) Service exited ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:24:05 (+0100) Waiting for Influx API
18.10.21 10:24:10 (+0100) Waiting for Influx API
18.10.21 10:24:13 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:24:15 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:24:16 (+0100) Waiting for Influx API
18.10.21 10:24:21 (+0100) Waiting for Influx API
18.10.21 10:24:26 (+0100) Waiting for Influx API
18.10.21 10:24:28 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:24:31 (+0100) Waiting for Influx API
18.10.21 10:24:35 (+0100) Restarting service ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:24:36 (+0100) Waiting for Influx API
18.10.21 10:24:41 (+0100) Waiting for Influx API
18.10.21 10:24:46 (+0100) Waiting for Influx API
18.10.21 10:24:48 (+0100) Service exited ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:24:51 (+0100) Waiting for Influx API
18.10.21 10:24:56 (+0100) Waiting for Influx API
18.10.21 10:25:01 (+0100) Waiting for Influx API
18.10.21 10:25:04 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:25:06 (+0100) Waiting for Influx API
18.10.21 10:25:11 (+0100) Waiting for Influx API
18.10.21 10:25:16 (+0100) Waiting for Influx API
18.10.21 10:25:17 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:25:21 (+0100) Waiting for Influx API
18.10.21 10:25:22 (+0100) Restarting service ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:25:22 (+0100) Starting service ‘influxdb sha256:5426da1fe5416ab2ec19ea8598054c840af9e41a56b877c94bcb533e54abf675’
18.10.21 10:25:26 (+0100) Waiting for Influx API
18.10.21 10:25:31 (+0100) Waiting for Influx API
18.10.21 10:25:34 (+0100) Service exited ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:25:37 (+0100) Waiting for Influx API
18.10.21 10:25:42 (+0100) Waiting for Influx API
18.10.21 10:25:46 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:25:47 (+0100) Waiting for Influx API
18.10.21 10:25:52 (+0100) Waiting for Influx API
18.10.21 10:25:57 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:25:57 (+0100) Waiting for Influx API
18.10.21 10:26:02 (+0100) Waiting for Influx API
18.10.21 10:26:04 (+0100) Restarting service ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:26:07 (+0100) Waiting for Influx API
18.10.21 10:26:12 (+0100) Waiting for Influx API
18.10.21 10:26:15 (+0100) Service exited ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:26:17 (+0100) Waiting for Influx API
18.10.21 10:26:22 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:26:22 (+0100) Waiting for Influx API
18.10.21 10:26:27 (+0100) Waiting for Influx API
18.10.21 10:26:32 (+0100) Waiting for Influx API
18.10.21 10:26:37 (+0100) Waiting for Influx API
18.10.21 10:26:42 (+0100) Waiting for Influx API
18.10.21 10:26:43 (+0100) Restarting service ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:26:47 (+0100) Waiting for Influx API
18.10.21 10:26:52 (+0100) Waiting for Influx API
18.10.21 10:26:57 (+0100) Waiting for Influx API
18.10.21 10:26:59 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:27:00 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:27:01 (+0100) Starting service ‘influxdb sha256:5426da1fe5416ab2ec19ea8598054c840af9e41a56b877c94bcb533e54abf675’
18.10.21 10:27:06 (+0100) Waiting for Influx API
18.10.21 10:27:10 (+0100) Waiting for Influx API
18.10.21 10:27:16 (+0100) Waiting for Influx API
18.10.21 10:27:21 (+0100) Waiting for Influx API
18.10.21 10:27:26 (+0100) Waiting for Influx API
18.10.21 10:27:31 (+0100) Waiting for Influx API
18.10.21 10:27:33 (+0100) Service exited ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:27:34 (+0100) Restarting service ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:27:36 (+0100) Waiting for Influx API
18.10.21 10:27:41 (+0100) Waiting for Influx API
18.10.21 10:27:46 (+0100) Waiting for Influx API
18.10.21 10:27:50 (+0100) Service exited ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:27:51 (+0100) Waiting for Influx API
18.10.21 10:27:57 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:27:56 (+0100) Waiting for Influx API
18.10.21 10:27:58 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:28:01 (+0100) Waiting for Influx API
18.10.21 10:28:07 (+0100) Waiting for Influx API
18.10.21 10:28:12 (+0100) Service exited ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:28:12 (+0100) Waiting for Influx API
18.10.21 10:28:17 (+0100) Waiting for Influx API
18.10.21 10:28:22 (+0100) Waiting for Influx API
18.10.21 10:28:25 (+0100) Restarting service ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:28:27 (+0100) Waiting for Influx API
18.10.21 10:28:32 (+0100) Waiting for Influx API
18.10.21 10:28:36 (+0100) Service exited ‘connector sha256:e877f7f6159360a931a074b88e489daf6e55f9444ee986ef330a7a75ac5ff9c1’
18.10.21 10:28:38 (+0100) Waiting for Influx API
18.10.21 10:28:40 (+0100) Restarting service ‘sensor sha256:d7a5c7c164dbe10e2d2252c4662f73422082937238be61ebb7f47c2c8b6035a5’
18.10.21 10:28:43 (+0100) Waiting for Influx API
18.10.21 10:28:48 (+0100) Waiting for Influx API
18.10.21 10:28:53 (+0100) Waiting for Influx API
18.10.21 10:28:58 (+0100) Waiting for Influx API
18.10.21 10:29:03 (+0100) Waiting for Influx API
