I use photon-nano CTI board with a Sierra Wireless, Incorporated EM7421 modem. BalenaOS version is 4.0.9
I tried add following UDEV rules in config.json on /mnt/boot.
SUBSYSTEMS=="usb", ATTRS{idVendor}=="1199", GOTO="mm_sierra_generic"
GOTO="mm_sierra_end"
LABEL="mm_sierra_generic"
SUBSYSTEMS=="usb", ATTRS{bInterfaceNumber}=="?*", ENV{.MM_USBIFNUM}="$attr{bInterfaceNumber}"
ATTRS{idVendor}=="1199", ATTRS{idProduct}=="9091", ENV{.MM_USBIFNUM}=="00", SUBSYSTEM=="tty", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="1199", ATTRS{idProduct}=="9091", ENV{.MM_USBIFNUM}=="00", SUBSYSTEM=="tty", ENV{ID_MM_PORT_IGNORE}="1"
ATTRS{idVendor}=="1199", ATTRS{idProduct}=="9091", ENV{.MM_USBIFNUM}=="00", SUBSYSTEM=="tty", ENV{ID_MM_TTY_MANUAL_SCAN_ONLY}="1"
ATTRS{idVendor}=="1199", ATTRS{idProduct}=="9091", ENV{.MM_USBIFNUM}=="01", SUBSYSTEM=="tty", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="1199", ATTRS{idProduct}=="9091", ENV{.MM_USBIFNUM}=="01", SUBSYSTEM=="tty", ENV{ID_MM_PORT_IGNORE}="1"
ATTRS{idVendor}=="1199", ATTRS{idProduct}=="9091", ENV{.MM_USBIFNUM}=="01", SUBSYSTEM=="tty", ENV{ID_MM_TTY_MANUAL_SCAN_ONLY}="1"
ATTRS{idVendor}=="1199", ATTRS{idProduct}=="9091", ENV{.MM_USBIFNUM}=="02", SUBSYSTEM=="tty", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idVendor}=="1199", ATTRS{idProduct}=="9091", ENV{.MM_USBIFNUM}=="02", SUBSYSTEM=="tty", ENV{ID_MM_PORT_IGNORE}="1"
ATTRS{idVendor}=="1199", ATTRS{idProduct}=="9091", ENV{.MM_USBIFNUM}=="02", SUBSYSTEM=="tty", ENV{ID_MM_TTY_MANUAL_SCAN_ONLY}="1"
LABEL="mm_sierra_end"
My final config.json was something like this. I used commands on here GitHub - balena-os/meta-balena: A collection of Yocto layers used to build balenaOS images
"developmentMode": true,
"deviceType": "photon-nano",
"os": {
"udevRules": {
"70-mm-sierra": "SUBSYSTEMS==\"usb\", ATTRS{idVendor}==\"1199\", GOTO=\"mm_sierra_generic\"\nGOTO=\"mm_sierra_end\"\nLABEL=\"mm_sierra_generic\"\nSUBSYSTEMS==\"usb\", ATTRS{bInterfaceNumber}==\"?*\", ENV{.MM_USBIFNUM}=\"$attr{bInterfaceNumber}\"\nATTRS{idVendor}==\"1199\", ATTRS{idProduct}==\"9091\", ENV{.MM_USBIFNUM}==\"00\", SUBSYSTEM==\"tty\", ENV{ID_MM_DEVICE_IGNORE}=\"1\"\nATTRS{idVendor}==\"1199\", ATTRS{idProduct}==\"9091\", ENV{.MM_USBIFNUM}==\"00\", SUBSYSTEM==\"tty\", ENV{ID_MM_PORT_IGNORE}=\"1\"\nATTRS{idVendor}==\"1199\", ATTRS{idProduct}==\"9091\", ENV{.MM_USBIFNUM}==\"00\", SUBSYSTEM==\"tty\", ENV{ID_MM_TTY_MANUAL_SCAN_ONLY}=\"1\"\nATTRS{idVendor}==\"1199\", ATTRS{idProduct}==\"9091\", ENV{.MM_USBIFNUM}==\"01\", SUBSYSTEM==\"tty\", ENV{ID_MM_DEVICE_IGNORE}=\"1\"\nATTRS{idVendor}==\"1199\", ATTRS{idProduct}==\"9091\", ENV{.MM_USBIFNUM}==\"01\", SUBSYSTEM==\"tty\", ENV{ID_MM_PORT_IGNORE}=\"1\"\nATTRS{idVendor}==\"1199\", ATTRS{idProduct}==\"9091\", ENV{.MM_USBIFNUM}==\"01\", SUBSYSTEM==\"tty\", ENV{ID_MM_TTY_MANUAL_SCAN_ONLY}=\"1\"\nATTRS{idVendor}==\"1199\", ATTRS{idProduct}==\"9091\", ENV{.MM_USBIFNUM}==\"02\", SUBSYSTEM==\"tty\", ENV{ID_MM_DEVICE_IGNORE}=\"1\"\nATTRS{idVendor}==\"1199\", ATTRS{idProduct}==\"9091\", ENV{.MM_USBIFNUM}==\"02\", SUBSYSTEM==\"tty\", ENV{ID_MM_PORT_IGNORE}=\"1\"\nATTRS{idVendor}==\"1199\", ATTRS{idProduct}==\"9091\", ENV{.MM_USBIFNUM}==\"02\", SUBSYSTEM==\"tty\", ENV{ID_MM_TTY_MANUAL_SCAN_ONLY}=\"1\"\nGOTO=\"mm_sierra_end\"\nLABEL=\"mm_sierra_end\"\n"
This created a 77-mm-sierra.rules file under /etc/udev/rules.d . However, when I run mmcli -L on HostOS I still see modem as
mmcli -L
/org/freedesktop/ModemManager1/Modem/0 [Sierra Wireless, Incorporated] EM7421
EDIT:
dmesg | grep usb log for modem:
[ 1.768777] usb 1-2.2: new high-speed USB device number 4 using tegra-xusb
[ 1.790427] usb 1-2.2: config 1 has an invalid interface number: 8 but max is 3
[ 1.790438] usb 1-2.2: config 1 has no interface number 1
[ 1.791496] usb 1-2.2: New USB device found, idVendor=1199, idProduct=9091
[ 1.791506] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.791513] usb 1-2.2: Product: Sierra Wireless EM7421 Qualcomm\xc2\xae Snapdragon\xe2\x84\xa2 X16 LTE-A
[ 1.791520] usb 1-2.2: Manufacturer: Sierra Wireless, Incorporated
[ 1.791527] usb 1-2.2: SerialNumber: 8G2324201704B128
[ 16.664568] usbcore: registered new interface driver qcserial
[ 16.664596] usbserial: USB Serial support registered for Qualcomm USB modem
[ 16.664644] usbcore: registered new interface driver btusb
[ 16.667802] usb 1-2.2: Qualcomm USB modem converter now attached to ttyUSB0
[ 16.671877] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 16.675728] usbcore: registered new interface driver rtk_btusb
[ 16.681299] usbcore: registered new interface driver cdc_wdm
[ 16.687477] usb 1-2.2: Qualcomm USB modem converter now attached to ttyUSB1
[ 16.689063] usb 1-2.2: Qualcomm USB modem converter now attached to ttyUSB2
I also fixed the syntax error in my udev rule above. Checked with udevadm test /dev/ttyUSB0
cmd to test it. It reads the rule but still mmcli -L returns me the modem.
Any ideas how to make ModemManager to IGNORE this modem? @mpous
edit 2:
Running udevadm info /dev/ttyUSB[0-1-2] shows similar results as here:
udevadm info /dev/ttyUSB2
P: /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.3/ttyUSB2/tty/ttyUSB2
N: ttyUSB2
L: 0
S: serial/by-path/platform-70090000.xusb-usb-0:2.2:1.3-port0
S: serial/by-id/usb-Sierra_Wireless__Incorporated_Sierra_Wireless_EM7421_Qualcomm®_Snapdragon™_X16_LTE-A_8G2324201704B128-if03-port0
E: DEVPATH=/devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.3/ttyUSB2/tty/ttyUSB2
E: DEVNAME=/dev/ttyUSB2
E: MAJOR=188
E: MINOR=2
E: SUBSYSTEM=tty
E: USEC_INITIALIZED=16904549
E: ID_VENDOR=Sierra_Wireless__Incorporated
E: ID_VENDOR_ENC=Sierra\x20Wireless\x2c\x20Incorporated
E: ID_VENDOR_ID=1199
E: ID_MODEL=Sierra_Wireless_EM7421_Qualcomm®_Snapdragon™_X16_LTE-A
E: ID_MODEL_ENC=Sierra\x20Wireless\x20EM7421\x20Qualcomm®\x20Snapdragon™\x20X16\x20LTE-A
E: ID_MODEL_ID=9091
E: ID_REVISION=0006
E: ID_SERIAL=Sierra_Wireless__Incorporated_Sierra_Wireless_EM7421_Qualcomm®_Snapdragon™_X16_LTE-A_8G2324201704B128
E: ID_SERIAL_SHORT=8G2324201704B128
E: ID_TYPE=generic
E: ID_BUS=usb
E: ID_USB_INTERFACES=:ffffff:ff0000:
E: ID_USB_INTERFACE_NUM=03
E: ID_USB_DRIVER=qcserial
E: ID_PATH=platform-70090000.xusb-usb-0:2.2:1.3
E: ID_PATH_TAG=platform-70090000_xusb-usb-0_2_2_1_3
E: ID_MM_DEVICE_IGNORE=1
E: ID_MM_PORT_IGNORE=1
E: ID_MM_CANDIDATE=1
E: DEVLINKS=/dev/serial/by-path/platform-70090000.xusb-usb-0:2.2:1.3-port0 /dev/serial/by-id/usb-Sierra_Wireless__Incorporated_Sierra_Wireless_EM7421_Qualcomm®_Snapdragon™_X16_LTE-A_8G2324201704B128-if03-port0
E: TAGS=:systemd:
E: CURRENT_TAGS=:systemd:
I see that ID_MM_PORT_IGNORE=1 and ID_MM_DEVICE_IGNORE=1. But mmcli -L still returns modem list. Are these ports ignored by mm or not I am confused
