I have a weird use case where I’m using a USB Bluetooth dongle as a BLE controller connected to a Pi Zero running Balena.
An issue I’m having is ModemManager seems to be flooding my USB serial port with AT commands, essentially reducing the useful data I can get out of it.
I’ve tried using dbus to disable ModemManager from inside a Debain container using:
DBUS_SYSTEM_BUS_ADDRESS=unix:path=/host/run/dbus/system_bus_socket \
dbus-send \
--system \
--reply-timeout=2000 \
--dest=org.freedesktop.systemd1 \
/org/freedesktop/systemd1 \
org.freedesktop.systemd1.Manager.StopUnit \
string:ModemManager.service string:fail
but it doesn’t seem to work - still a bunch of random AT commands being fed through that serial port (/dev/ttyACM0).
Any ideas?
