BALENA WONT CREATE REALESE FROM GITHUB DEPLOY
Hi!
balena wont create realese from GitHub - NebraLtd/helium-controllino: Nebra OpenFleet for Controllino Miners
ss from balena error: https://cdn.discordapp.com/attachments/1019646912854495324/1138749041220526130/image.png
Hi, can you please share how you are trying to create the release?
I press deploy with balena on link: GitHub - NebraLtd/helium-controllino: Nebra OpenFleet for Controllino Miners
then automaticly open balena dashboard and I need to choose wich fleet, when I chosed fleet show errors… i created 25 times, and no problem
Hello, are you choosing an existing fleet or creating a new fleet when you use the deploy with balena link? What kind of errors are you seeing?
Im choosing existing fleet
erros on URL: https://cdn.discordapp.com/attachments/1019646912854495324/1138749041220526130/image.png
Hi, we had a bug in the dashboard with the Deploy with Balena modal that was patched today. It made it so that you were able to select multiple applications to deploy to, but that wasn’t actually an intended feature and thus did not work properly. Were you seeing this behavior when trying to deploy? Did you have more than one fleet selected? Could you please try again now that that bug is patched?
