My device is running BalenaOS 2.84.5 and Supervisor version 12.10.3. Using Supervisor version 14.11.9 gives the same result.
[CMD] in the service is set to run a start-script at startup which has a balena-idle at the end of it.
When the device has been running for a while, this shows up in the log:
2023-09-08T10:23:09 main Idling...
2023-09-08T10:33:09 main Idling...
2023-09-08T11:45:01 Supervisor starting
(*start-script runs again)
It says Supervisor starting and the service becomes unusable. The container isn’t restarted, it just stops communicating with the device hardware. Isn’t the Supervisor only supposed to be started at device startup? The starts seem random to me since I don’t know why they occur.
Expected behavior would be that the Supervisor is started when the device is powered on and starts the service. Once the service is up and running, the Supervisor should not affect the service unless a command from balena is sent.
Is there any way to stop the Supervisor from starting randomly or is there a way to live with it and keep the container running even if Supervisor is starting?
I would really appreiate any support or input on this.
Best regards,
