You can get most of the relevant logs from device diagnostics in the dashboard. To do so navigate to diagnostics tab of the said device and check the run device diagnostic. It will post with most of the relevant logs for us to diagnose.
I did that but this grabs logs that appear to be all dated Nov 06 (today).
The device is no longer in a bad state.
The issue in question occurred on Nov 03.
