Just testing balena-sense with a custom setup, have removed the sensor service in favour of MQTT data input, as there are no local sensors attached. The external sensors are not connecting over MQTT but the first problem is there are no logs being generated. Other than removing the sensor service the rest of the compose file remains untouched. Any idea why there are no logs?
This was due to a partial outage @n1md4, but it should now be resolved. Go ahead and check again if you can, thanks!
Yes, resolved. Thank you for the info!
Awesome, glad to hear.
