wlisac
February 29, 2020, 6:03am
1
Hi there,
I’m wondering if there are plans to support an official GitHub Action to push code to a BalenaCloud app using the Balena CLI?
@shaunmulligan – I’ve seen this on the product roadmap, but I’m not sure if it’s specific to a GitHub Action: https://trello.com/c/ElN82kKs/73-deploy-from-a-github-repository
This community action is helpful, but it’s slow since it builds from source (and it’s not versioned): https://github.com/theaccordance/balena-push
It’s relatively straightforward to DIY with something like this, but I think being able to use an official (and versioned) action would be a great addition.
- name: Balena Push
run: |
curl -L -o /tmp/balena.zip https://github.com/balena-io/balena-cli/releases/download/v11.28.5/balena-cli-v11.28.5-linux-x64-standalone.zip
unzip /tmp/balena.zip -d /opt
rm /tmp/balena.zip
export PATH=$PATH:/opt/balena-cli
balena login --token ${{secrets.BALENA_TOKEN}}
balena push My-App
Hey,
Thanks for sharing this; I personally wasn’t aware of the project you linked.
It has been made aware to our product team and I believe that they will be discussing the possibility of us providing an official action soon.
rapha
February 11, 2021, 11:53pm
6
@richbayliss Great to hear. Any progress to report on this? There are a couple of actions I am aware of, such as: GitHub - bekriebel/balena-cli-action: Continuously deploy your application to BalenaCloud but they seem rather outdated.
ping the progress, I am too could not use any pre-build actions
+1 on this. I too tried all the community built Github Actions, but none worked and all seemed outdated.
An official Github Action from Balena would be glorious.
mpous
June 21, 2021, 11:23am
11
@barryjump @circleoncircles let me share with you something that it’s still work in progress but it would be cool to get your feedback and maybe contributions?
Remember, this repo is on balena-io-playground, so that means that it’s not ready for production and it’s still WIP. But glad to learn what do you think.
rapha
July 15, 2021, 12:20pm
16
We manage to push via a Github Action, but had to manually update one of the existing balena github actions to use the newest balena cli.
We have a few specialities such as
pulling pre-built images prior to deployment from both Github and Gitlab - We have native arm64 runners that are significantly quicker than balena’s - we thus also deploy using the --emulate tag to hit the quicker balena x86 runners
having to handle submodules
Caching through the image itself (will blow up the image size - do something else)
Tag the balena release with the branch or git tag, as well as the git SHA
My workflow file looks like this:
name: Build Docker images and deploy to Balena
on:
push:
branches:
- "master"
workflow_dispatch:
jobs:
docker:
runs-on: ubuntu-latest
steps:
- name: Checkout
uses: actions/checkout@v2
- name: checkout submodules using deploy ssh key
env:
SSH_KEY: ${{ secrets.DEPLOY_SSH_KEY }}
run: |
mkdir $HOME/.ssh && echo "$SSH_KEY" > $HOME/.ssh/id_rsa && chmod 600 $HOME/.ssh/id_rsa
ssh-keyscan -t rsa github.com >> ~/.ssh/known_hosts
ssh-keyscan -t rsa gitlab.com >> ~/.ssh/known_hosts
git submodule sync --recursive
git submodule update --init --recursive --force
- name: Set up QEMU
uses: docker/setup-qemu-action@v1
- name: Set up Docker Buildx
uses: docker/setup-buildx-action@v1
- name: Login to DockerHub
uses: docker/login-action@v1
with:
registry: ghcr.io
username: ${{ github.repository_owner }}
password: ${{ secrets.GITHUB_TOKEN }}
- name: Build and push Build Do image
uses: docker/build-push-action@v2
with:
context: .
file: nx.Dockerfile
push: true
tags: ghcr.io/SOME_ORG/SOME_IMAGE
platforms: linux/arm64
cache-from: type=registry,ref=ghcr.io/SOME_ORG/SOME_IMAGE
cache-to: type=inline
name: "Pull containers"
run: docker-compose pull
uses: aivero/balena-cli-action@master
if: success()
timeout-minutes: 15
with:
balena_api_token: ${{ secrets.BALENA_TOKEN }}
balena_command: balena deploy SOME_BALENA_APPLICATION --emulated
balena_secrets: |
"ghcr.io": {
"username": "${{ github.actor }}",
"password": "${{ secrets.GITHUB_TOKEN }}"
name: Balena tag release with git ref
if: success()
timeout-minutes: 5
with:
balena_command: balena app SOME_BALENA_APPLICATION | grep COMMIT | awk '{print $2}' | xargs balena tag set version ${{ github.ref }} --release
name: Balena tag telease with git SHA
if: success()
timeout-minutes: 5
with:
balena_command: balena app SOME_BALENA_APPLICATION | grep COMMIT | awk '{print $2}' | xargs balena tag set commit_sha ${{ github.sha }} --release
Hey thanks for the feedback, ill forward to the team that’s working on this so they are aware of the use case.
