NEED HELP ASAP
I wanted certain plugins to be available inside container. Having Ubuntu 18.04 as host on Jetson Nano SD Card, after using the command ‘docker run -it --runtime nvidia bash’, I could access the container and those plugins were available in the docker. These plugins were also available in Ubuntu 18.04. Now, I have latest balenaOS image in Jetson Nano SD Card. I have this image: nvcr.io/nvidia/l4t-base:r32.5.0 as container having l4t 32.5 same as balenaOS latest version. After running the command ‘balena run -it --runtime nvidia 526835774af8 bash’, I am getting this error: ‘balena run -it --runtime nvidia 526835774af8 bash balena: Error response from daemon: Unknown runtime specified nvidia.
See ‘balena run --help’.’. I tried using it with --privileged flag. Also, I tried using the command ‘balena run -it --gpus all 526835774af8 bash’. I am not able to see those plugins inside the docker.
Also, does balenaOS have omxh264dec.
