following problem, today came my POE Hat for the RasPi4.
So far it works, the fan starts and stops again.
However, I can not edit the config of the fan. On the SD card I have adjusted the config.txt under boot as follows:
You can access the dtoverlay and dtparam configuration in the dashboard under ‘Device configuration’. Values added here get passed to the config.txt file automatically.
The option you’re looking for is “Define DT parameters for the default overlay.” and “Define DT overlays”. They may already have values, but you can add to them.
To get all the params in you’d have to input them like this: "poe_fan_temp0=10000,poe_fan_temp1_hyst=1000","poe_fan_temp1=60000,poe_fan_temp2_hyst=5000","dtparam=poe_fan_temp2=65000,poe_fan_temp3_hyst=5000","dtparam=poe_fan_temp3=70000,poe_fan_temp3_hyst=5000"
