I discovered that the tool tip in the Balena Dashboard → Device Configuration for the GPIO settings is confusing/wrong. Specifically, I’m talking about the tooltip that accompanies the Allows GPIO pins to be set to specific modes and values at boot time option.
When you enable this option and edit it, the dialog that pops up has a tool tip in it purporting to show the correct format for this setting:
However, if you enter the text exactly as shown (e.g. "gpio=19=op,dh","gpio=0-25=a2"), I have found that this will not correctly set the GPIO states on boot.
Rather, you have to enter the settings without the gpio= prefix. For the above, you would enter "19=op,dh","0-25=a2". I have found that this does work.
Not a big deal, but cost me some time to figure out why my GPIO settings weren’t working ![]()
