Balena OS for containers mounted as Read-Only
I have a device that’s showing weird a behavior… Almost nothing except BalenaVPN is starting on the device, not even Balena Engine.
There is not a lot to check except the DMESG logs below, which confirm the issues of the device.
[    3.963396] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
[    3.963405] libphy: r8169: probed
[    3.963881] r8169 0000:02:00.0 eth1: RTL8168evl/8111evl, 40:62:31:14:06:91, XID 2c9, IRQ 121
[    3.963889] r8169 0000:02:00.0 eth1: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[    3.964811] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    3.985810] at24 0-0050: 256 byte spd EEPROM, read-only
[    4.098388] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC662 rev3: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    4.098395] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    4.098398] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    4.098400] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    4.098402] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    4.098405] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    4.098408] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    4.126533] r8169 0000:01:00.0 enp1s0: renamed from eth0
[    4.129106] zram: Can't change algorithm for initialized device
[    4.140087] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[    4.149327] r8169 0000:02:00.0 enp2s0: renamed from eth1
[    4.164312] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[    4.164677] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[    4.164984] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[    4.165278] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[    4.165682] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[    4.165976] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    4.166270] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[    4.343998] Adding 4030788k swap on /dev/zram0.  Priority:-2 extents:1 across:4030788k SS
[    4.379240] random: crng init done
[    4.480714] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[    4.666068] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[    6.828058] r8169 0000:01:00.0: Direct firmware load for rtl_nic/rtl8168e-3.fw failed with error -2
[    6.828069] r8169 0000:01:00.0: Unable to load firmware rtl_nic/rtl8168e-3.fw (-2)
[    6.828578] RTL8211E Gigabit Ethernet r8169-100:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-100:00, irq=IGNORE)
[    6.894692] r8169 0000:01:00.0 enp1s0: Link is Down
[    6.901702] r8169 0000:02:00.0: Direct firmware load for rtl_nic/rtl8168e-3.fw failed with error -2
[    6.901711] r8169 0000:02:00.0: Unable to load firmware rtl_nic/rtl8168e-3.fw (-2)
[    6.902858] RTL8211E Gigabit Ethernet r8169-200:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[    6.967556] r8169 0000:02:00.0 enp2s0: Link is Down
[    9.518380] r8169 0000:02:00.0 enp2s0: Link is Up - 1Gbps/Full - flow control off
[    9.518400] IPv6: ADDRCONF(NETDEV_CHANGE): enp2s0: link becomes ready
[   38.074009] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[   38.074039] ata2.00: failed command: WRITE DMA EXT
[   38.074076] ata2.00: cmd 35/00:40:50:f2:15/00:05:00:00:00/e0 tag 20 dma 688128 out
                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[   38.074090] ata2.00: status: { DRDY }
[   38.074114] ata2: hard resetting link
[   38.384970] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   38.391197] ata2.00: configured for UDMA/133
[   38.391235] ata2.00: device reported invalid CHS sector 0
[   38.391288] ata2: EH complete
[   68.787024] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[   68.787056] ata2.00: failed command: WRITE DMA EXT
[   68.787095] ata2.00: cmd 35/00:40:50:f2:15/00:05:00:00:00/e0 tag 10 dma 688128 out
[   68.787110] ata2.00: status: { DRDY }
[   68.787134] ata2: hard resetting link
[   69.095722] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   69.102020] ata2.00: configured for UDMA/133
[   69.102057] ata2.00: device reported invalid CHS sector 0
[   69.102108] ata2: EH complete
[   99.503005] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[   99.503038] ata2.00: failed command: WRITE DMA EXT
[   99.503078] ata2.00: cmd 35/00:40:50:f2:15/00:05:00:00:00/e0 tag 17 dma 688128 out
[   99.503094] ata2.00: status: { DRDY }
[   99.503118] ata2: hard resetting link
[   99.816729] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[   99.822800] ata2.00: configured for UDMA/133
[   99.822835] ata2.00: device reported invalid CHS sector 0
[   99.822887] ata2: EH complete
[  130.222996] ata2: limiting SATA link speed to 3.0 Gbps
[  130.223024] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  130.223051] ata2.00: failed command: WRITE DMA EXT
[  130.223089] ata2.00: cmd 35/00:40:50:f2:15/00:05:00:00:00/e0 tag 7 dma 688128 out
[  130.223103] ata2.00: status: { DRDY }
[  130.223130] ata2: hard resetting link
[  130.536795] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[  130.543227] ata2.00: configured for UDMA/133
[  130.543265] ata2.00: device reported invalid CHS sector 0
[  130.543317] ata2: EH complete
[  160.943002] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  160.943033] ata2.00: failed command: WRITE DMA EXT
[  160.943074] ata2.00: cmd 35/00:40:50:f2:15/00:05:00:00:00/e0 tag 23 dma 688128 out
[  160.943089] ata2.00: status: { DRDY }
[  160.943112] ata2: hard resetting link
[  161.256061] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[  161.261958] ata2.00: configured for UDMA/133
[  161.261996] ata2.00: device reported invalid CHS sector 0
[  161.262049] ata2: EH complete
[  191.663004] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  191.663035] ata2.00: failed command: WRITE DMA EXT
[  191.663075] ata2.00: cmd 35/00:40:50:f2:15/00:05:00:00:00/e0 tag 1 dma 688128 out
                        res 40/00:01:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[  191.663091] ata2.00: status: { DRDY }
[  191.663115] ata2: hard resetting link
[  191.975647] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[  191.982073] ata2.00: configured for UDMA/133
[  191.982201] sd 1:0:0:0: [sdb] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=183s
[  191.982225] sd 1:0:0:0: [sdb] tag#1 Sense Key : 0x5 [current]
[  191.982241] sd 1:0:0:0: [sdb] tag#1 ASC=0x21 ASCQ=0x4
[  191.982260] sd 1:0:0:0: [sdb] tag#1 CDB: opcode=0x2a 2a 00 00 15 f2 50 00 05 40 00
[  191.982284] blk_update_request: I/O error, dev sdb, sector 1438288 op 0x1:(WRITE) flags 0x4800 phys_seg 168 prio class 0
[  191.982308] Buffer I/O error on dev sdb6, logical block 1610, lost sync page write
[  191.982594] ata2: EH complete
[  222.394064] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  222.394095] ata2.00: failed command: WRITE DMA EXT
[  222.394133] ata2.00: cmd 35/00:40:90:f7:15/00:05:00:00:00/e0 tag 13 dma 688128 out
[  222.394148] ata2.00: status: { DRDY }
[  222.394172] ata2: hard resetting link
[  222.704717] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[  222.710749] ata2.00: configured for UDMA/133
[  222.710823] ata2: EH complete
[  253.102997] ata2: limiting SATA link speed to 1.5 Gbps
[  253.103025] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  253.103051] ata2.00: failed command: WRITE DMA EXT
[  253.103090] ata2.00: cmd 35/00:40:90:f7:15/00:05:00:00:00/e0 tag 3 dma 688128 out
[  253.103104] ata2.00: status: { DRDY }
[  253.103131] ata2: hard resetting link
[  253.416801] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  253.422888] ata2.00: configured for UDMA/133
[  253.422969] ata2.00: device reported invalid CHS sector 0
[  253.423019] ata2: EH complete
[  283.823112] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  283.823144] ata2.00: failed command: WRITE DMA EXT
[  283.823186] ata2.00: cmd 35/00:40:90:f7:15/00:05:00:00:00/e0 tag 18 dma 688128 out
[  283.823202] ata2.00: status: { DRDY }
[  283.823226] ata2: hard resetting link
[  284.136595] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  284.142454] ata2.00: configured for UDMA/133
[  284.142488] ata2.00: device reported invalid CHS sector 0
[  284.142539] ata2: EH complete
[  314.543004] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  314.543037] ata2.00: failed command: WRITE DMA EXT
[  314.543078] ata2.00: cmd 35/00:40:90:f7:15/00:05:00:00:00/e0 tag 8 dma 688128 out
[  314.543092] ata2.00: status: { DRDY }
[  314.543117] ata2: hard resetting link
[  314.854594] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  314.860461] ata2.00: configured for UDMA/133
[  314.860497] ata2.00: device reported invalid CHS sector 0
[  314.860544] ata2: EH complete
[  332.969030] EXT4-fs (sdb6): error count since last fsck: 5
[  332.969049] EXT4-fs (sdb6): initial error at time 1645124929: ext4_journal_check_start:83
[  332.969060] EXT4-fs (sdb6): last error at time 1645124946: ext4_journal_check_start:83
[  332.969069] EXT4-fs (sdb5): error count since last fsck: 2
[  332.969073] EXT4-fs (sdb5): initial error at time 1645126697: ext4_validate_inode_bitmap:105
[  332.969085] EXT4-fs (sdb5): last error at time 1645126727: ext4_journal_check_start:83
[  345.263069] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  345.263102] ata2.00: failed command: WRITE DMA EXT
[  345.263144] ata2.00: cmd 35/00:40:90:f7:15/00:05:00:00:00/e0 tag 15 dma 688128 out
[  345.263160] ata2.00: status: { DRDY }
[  345.263186] ata2: hard resetting link
[  345.576978] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  345.582833] ata2.00: configured for UDMA/133
[  345.582868] ata2.00: device reported invalid CHS sector 0
[  345.583026] ata2: EH complete
[  375.982998] ata2.00: limiting speed to UDMA/100:PIO4
[  375.983025] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  375.983052] ata2.00: failed command: WRITE DMA EXT
[  375.983087] ata2.00: cmd 35/00:40:90:f7:15/00:05:00:00:00/e0 tag 24 dma 688128 out
[  375.983101] ata2.00: status: { DRDY }
[  375.983125] ata2: hard resetting link
[  376.295865] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  376.302001] ata2.00: configured for UDMA/100
[  376.302035] ata2.00: device reported invalid CHS sector 0
[  376.302125] sd 1:0:0:0: [sdb] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=184s
[  376.302145] sd 1:0:0:0: [sdb] tag#24 Sense Key : 0x5 [current]
[  376.302161] sd 1:0:0:0: [sdb] tag#24 ASC=0x21 ASCQ=0x4
[  376.302181] sd 1:0:0:0: [sdb] tag#24 CDB: opcode=0x2a 2a 00 00 15 f7 90 00 05 40 00
[  376.302201] blk_update_request: I/O error, dev sdb, sector 1439632 op 0x1:(WRITE) flags 0x4800 phys_seg 168 prio class 0
[  376.302484] ata2: EH complete
[  406.714056] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  406.714089] ata2.00: failed command: WRITE DMA EXT
[  406.714127] ata2.00: cmd 35/00:40:d0:fc:15/00:05:00:00:00/e0 tag 27 dma 688128 out
[  406.714144] ata2.00: status: { DRDY }
[  406.714169] ata2: hard resetting link
[  407.024096] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  407.029979] ata2.00: configured for UDMA/100
[  407.030014] ata2.00: device reported invalid CHS sector 0
[  407.030062] ata2: EH complete
[  437.423003] ata2.00: limiting speed to UDMA/33:PIO4
[  437.423030] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  437.423054] ata2.00: failed command: WRITE DMA EXT
[  437.423091] ata2.00: cmd 35/00:40:d0:fc:15/00:05:00:00:00/e0 tag 13 dma 688128 out
[  437.423108] ata2.00: status: { DRDY }
[  437.423134] ata2: hard resetting link
[  437.735844] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  437.741897] ata2.00: configured for UDMA/33
[  437.742018] ata2: EH complete
[  468.143007] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  468.143040] ata2.00: failed command: WRITE DMA EXT
[  468.143081] ata2.00: cmd 35/00:40:d0:fc:15/00:05:00:00:00/e0 tag 22 dma 688128 out
[  468.143096] ata2.00: status: { DRDY }
[  468.143119] ata2: hard resetting link
[  468.456861] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  468.462800] ata2.00: configured for UDMA/33
[  468.462836] ata2.00: device reported invalid CHS sector 0
[  468.462886] ata2: EH complete
[  498.863007] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  498.863039] ata2.00: failed command: WRITE DMA EXT
[  498.863079] ata2.00: cmd 35/00:40:d0:fc:15/00:05:00:00:00/e0 tag 2 dma 688128 out
[  498.863094] ata2.00: status: { DRDY }
[  498.863117] ata2: hard resetting link
[  499.176835] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  499.182988] ata2.00: configured for UDMA/33
[  499.183026] ata2.00: device reported invalid CHS sector 0
[  499.183075] ata2: EH complete
[  529.582997] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  529.583028] ata2.00: failed command: WRITE DMA EXT
[  529.583067] ata2.00: cmd 35/00:40:d0:fc:15/00:05:00:00:00/e0 tag 20 dma 688128 out
[  529.583083] ata2.00: status: { DRDY }
[  529.583107] ata2: hard resetting link
[  529.896663] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  529.902951] ata2.00: configured for UDMA/33
[  529.902986] ata2.00: device reported invalid CHS sector 0
[  529.903036] ata2: EH complete
[  560.302996] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[  560.303029] ata2.00: failed command: WRITE DMA EXT
[  560.303068] ata2.00: cmd 35/00:40:d0:fc:15/00:05:00:00:00/e0 tag 24 dma 688128 out
[  560.303086] ata2.00: status: { DRDY }
[  560.303110] ata2: hard resetting link
[  560.616797] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  560.622812] ata2.00: configured for UDMA/33
[  560.622847] ata2.00: device reported invalid CHS sector 0
[  560.622990] sd 1:0:0:0: [sdb] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08 cmd_age=184s
[  560.623014] sd 1:0:0:0: [sdb] tag#24 Sense Key : 0x5 [current]
[  560.623030] sd 1:0:0:0: [sdb] tag#24 ASC=0x21 ASCQ=0x4
[  560.623050] sd 1:0:0:0: [sdb] tag#24 CDB: opcode=0x2a 2a 00 00 15 fc d0 00 05 40 00
[  560.623071] blk_update_request: I/O error, dev sdb, sector 1440976 op 0x1:(WRITE) flags 0x4800 phys_seg 168 prio class 0
[  560.623352] ata2: EH complete
[  560.625249] Aborting journal on device sdb6-8.
[  560.750613] EXT4-fs error (device sdb6): ext4_journal_check_start:83: Detected aborted journal
[  560.750622] EXT4-fs (sdb6): Remounting filesystem read-only
Could this be a corrupted OS Drive? Not sure… I mean I can access the HOST OS, so the device is booting and starting the VPN.
Please advice on possible device recovery.
Regards
Hi, this looks indeed like a corrupted partition. As the root filesystem in balenaOS is read-only, the device is able to boot and you should be able to manually repair the sdb6 drive.
I would suggest you make sure the engine and supervisor are stopped and perform a manual fsck on /dev/sdb6.
