We have a Compulab IOT-Gate-IMX8Plus that runs balenaOS 5.1.9 and Supervisor Version 15.2.0
I moved this device to a new fleet and then I became aware of its ‘VPN Only’ status.
I have logged into the device, and it seems that the balena service is trying to activate but it keeps failing.
Executing ‘balena ps’ returned the following message: Cannot connect to the balenaEngine daemon at unix:///var/run/balena-engine.sock. Is the balenaEngine daemon running?
I saw on other threads it can be disk space related, but it seems like there is enough space:
root@36325ff:~# df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 1.5G 0 1.5G 0% /dev
tmpfs 1.8G 42M 1.8G 3% /run
/dev/mmcblk2p2 451M 311M 113M 74% /mnt/sysroot/active
/dev/disk/by-state/resin-state 18M 82K 16M 1% /mnt/state
overlay 451M 311M 113M 74% /
/dev/mmcblk2p6 28G 4.1G 23G 16% /mnt/data
tmpfs 1.8G 0 1.8G 0% /dev/shm
tmpfs 4.0M 0 4.0M 0% /sys/fs/cgroup
tmpfs 1.8G 88K 1.8G 1% /tmp
/dev/mmcblk2p1 40M 1.9M 39M 5% /mnt/boot
tmpfs 1.8G 56K 1.8G 1% /var/volatile
root@36325ff:~# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
devtmpfs 368189 534 367655 1% /dev
tmpfs 461477 957 460520 1% /run
/dev/mmcblk2p2 60960 5599 55361 10% /mnt/sysroot/active
/dev/disk/by-state/resin-state 5112 81 5031 2% /mnt/state
overlay 60960 5599 55361 10% /
/dev/mmcblk2p6 2764800 142123 2622677 6% /mnt/data
tmpfs 461477 1 461476 1% /dev/shm
tmpfs 1024 17 1007 2% /sys/fs/cgroup
tmpfs 1048576 18 1048558 1% /tmp
/dev/mmcblk2p1 0 0 0 - /mnt/boot
tmpfs 461477 57 461420 1% /var/volatile
Here are some more logs:
root@36325ff:~# systemctl status balena-engine
× balena.service - Balena Application Container Engine
Loaded: loaded (/lib/systemd/system/balena.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/balena.service.d
└─storagemigration.conf
Active: failed (Result: exit-code) since Thu 2024-05-16 07:33:40 UTC; 571ms ago
TriggeredBy: × balena-engine.socket
Docs: https://www.balena.io/docs/getting-started
Process: 833600 ExecStart=/usr/bin/healthdog --healthcheck=${BALENAD_HEALTHDOG_HEALTHCHECK} /usr/bin/balenad $BALENAD_EXPERIMENTAL $BALENAD_DEBUG $BALENAD_LOGDRIVER $BALENAD_STORAGEDRIVER $BALENAD_HOST $BALENAD_DATA_ROOT $BALENAD_DELTA_STORAGEDRIVER $BALENAD_DELTA_DATA_ROOT $BALENAD_EXEC_ROOT $BALENAD_PIDFILE $BALENAD_DNS $BALENAD_BIP $BALENAD_CIDR $BALENAD_IPTABLES $BALENAD_MAX_DL_ATTEMPTS $BALENAD_CGROUPDRIVER $BALENAD_EXTRA_ARGS $BALENA_DEVELOPMENT_ARGS (code=exited, status=1/FAILURE)
Main PID: 833600 (code=exited, status=1/FAILURE)
Tasks: 76 (limit: 3451)
Memory: 84.4M
CGroup: /system.slice/balena.service
├─ 831269 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831268
├─ 831301 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831296
├─ 831343 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831342
├─ 831371 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831370
├─ 831397 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831396
├─ 831422 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831421
├─ 831455 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831450
├─ 831500 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831498
├─ 831528 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831527
├─ 831554 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831553
├─ 831579 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831578
├─ 831611 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831606
├─ 831654 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831653
├─ 831680 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831679
├─ 831704 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831703
├─ 831729 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831728
├─ 831762 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831757
├─ 831805 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831804
├─ 831833 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831832
├─ 831858 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831857
├─ 831883 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831882
├─ 831916 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831911
├─ 831958 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831956
├─ 831985 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 831984
├─ 832010 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832009
├─ 832035 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832034
├─ 832067 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832062
├─ 832111 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832109
├─ 832138 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832137
├─ 832164 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832163
├─ 832190 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832189
├─ 832222 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832217
├─ 832265 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832264
├─ 832293 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832292
├─ 832318 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832317
├─ 832343 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832342
├─ 832387 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832382
├─ 832430 /proc/self/exe --healthcheck /usr/lib/balena/balena-healthcheck --pid 832428
These logs are after I tried to start balena service using systemctl start balena:
root@36325ff:~# journalctl -xeu balena.service
May 16 07:46:38 36325ff balenad[843774]: time="2024-05-16T07:46:38.454338026Z" level=info msg="Starting up"
May 16 07:46:38 36325ff balenad[843774]: time="2024-05-16T07:46:38.454454157Z" level=warning msg="Running experimental build"
May 16 07:46:38 36325ff balenad[841410]: Parent process exited
May 16 07:46:38 36325ff balenad[843774]: time="2024-05-16T07:46:38.458789990Z" level=info msg="libcontainerd: started new balena-engine-containerd process" pid=843786
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38Z" level=warning msg="containerd config version `1` has been deprecated and will be removed in containerd v2.0, please switch to version `2`, >
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.571160382Z" level=info msg="starting containerd" revision= version=1.6.6+unknown
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.653745721Z" level=info msg="loading plugin \"io.containerd.content.v1.content\"..." type=io.containerd.content.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.653941355Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.aufs\"..." type=io.containerd.snapshotter.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.657171510Z" level=info msg="skip loading plugin \"io.containerd.snapshotter.v1.aufs\"..." error="aufs is not supported (modprobe aufs failed:>
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.657302266Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.native\"..." type=io.containerd.snapshotter.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.657427398Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.overlayfs\"..." type=io.containerd.snapshotter.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.657957798Z" level=info msg="loading plugin \"io.containerd.metadata.v1.bolt\"..." type=io.containerd.metadata.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.658060928Z" level=info msg="metadata content store policy set" policy=shared
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.658425320Z" level=info msg="loading plugin \"io.containerd.differ.v1.walking\"..." type=io.containerd.differ.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.658525325Z" level=info msg="loading plugin \"io.containerd.event.v1.exchange\"..." type=io.containerd.event.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.658597079Z" level=info msg="loading plugin \"io.containerd.gc.v1.scheduler\"..." type=io.containerd.gc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.658700709Z" level=info msg="loading plugin \"io.containerd.service.v1.introspection-service\"..." type=io.containerd.service.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.658762712Z" level=info msg="loading plugin \"io.containerd.service.v1.containers-service\"..." type=io.containerd.service.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.658825090Z" level=info msg="loading plugin \"io.containerd.service.v1.content-service\"..." type=io.containerd.service.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.658883092Z" level=info msg="loading plugin \"io.containerd.service.v1.diff-service\"..." type=io.containerd.service.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.658944720Z" level=info msg="loading plugin \"io.containerd.service.v1.images-service\"..." type=io.containerd.service.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.659006973Z" level=info msg="loading plugin \"io.containerd.service.v1.leases-service\"..." type=io.containerd.service.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.659066226Z" level=info msg="loading plugin \"io.containerd.service.v1.namespaces-service\"..." type=io.containerd.service.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.659127854Z" level=info msg="loading plugin \"io.containerd.service.v1.snapshots-service\"..." type=io.containerd.service.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.659184232Z" level=info msg="loading plugin \"io.containerd.runtime.v1.linux\"..." type=io.containerd.runtime.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.659640754Z" level=info msg="loading plugin \"io.containerd.runtime.v2.task\"..." type=io.containerd.runtime.v2
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.659950894Z" level=info msg="loading plugin \"io.containerd.monitor.v1.cgroups\"..." type=io.containerd.monitor.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.661433090Z" level=info msg="loading plugin \"io.containerd.service.v1.tasks-service\"..." type=io.containerd.service.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.661591597Z" level=info msg="loading plugin \"io.containerd.grpc.v1.introspection\"..." type=io.containerd.grpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.661665476Z" level=info msg="loading plugin \"io.containerd.internal.v1.restart\"..." type=io.containerd.internal.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.661856110Z" level=info msg="loading plugin \"io.containerd.grpc.v1.containers\"..." type=io.containerd.grpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.661927113Z" level=info msg="loading plugin \"io.containerd.grpc.v1.content\"..." type=io.containerd.grpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.661994867Z" level=info msg="loading plugin \"io.containerd.grpc.v1.diff\"..." type=io.containerd.grpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662056370Z" level=info msg="loading plugin \"io.containerd.grpc.v1.events\"..." type=io.containerd.grpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662119623Z" level=info msg="loading plugin \"io.containerd.grpc.v1.healthcheck\"..." type=io.containerd.grpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662182501Z" level=info msg="loading plugin \"io.containerd.grpc.v1.images\"..." type=io.containerd.grpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662261504Z" level=info msg="loading plugin \"io.containerd.grpc.v1.leases\"..." type=io.containerd.grpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662326383Z" level=info msg="loading plugin \"io.containerd.grpc.v1.namespaces\"..." type=io.containerd.grpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662396261Z" level=info msg="loading plugin \"io.containerd.grpc.v1.snapshots\"..." type=io.containerd.grpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662458389Z" level=info msg="loading plugin \"io.containerd.grpc.v1.tasks\"..." type=io.containerd.grpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662523642Z" level=info msg="loading plugin \"io.containerd.grpc.v1.version\"..." type=io.containerd.grpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662612271Z" level=info msg="loading plugin \"io.containerd.tracing.processor.v1.otlp\"..." type=io.containerd.tracing.processor.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662699526Z" level=info msg="skip loading plugin \"io.containerd.tracing.processor.v1.otlp\"..." error="no OpenTelemetry endpoint: skip plugin" type=io.containerd.tracing.processor.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662765029Z" level=info msg="loading plugin \"io.containerd.internal.v1.tracing\"..." type=io.containerd.internal.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662848158Z" level=error msg="failed to initialize a tracing processor \"otlp\"" error="no OpenTelemetry endpoint: skip plugin"
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.662974289Z" level=info msg="loading plugin \"io.containerd.ttrpc.v1.task\"..." type=io.containerd.ttrpc.v1
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.663052792Z" level=warning msg="failed to load plugin io.containerd.ttrpc.v1.task" error="no io.containerd.event.v1 plugins with id publisher: not found"
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.663649821Z" level=info msg=serving... address=/var/run/balena-engine/containerd/balena-engine-containerd-debug.sock
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.663917959Z" level=info msg=serving... address=/var/run/balena-engine/containerd/balena-engine-containerd.sock.ttrpc
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.664128719Z" level=info msg=serving... address=/var/run/balena-engine/containerd/balena-engine-containerd.sock
May 16 07:46:38 36325ff balenad[843786]: time="2024-05-16T07:46:38.664212348Z" level=info msg="containerd successfully booted in 0.096683s"
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.152028053Z" level=info msg="loading plugin \"io.containerd.differ.v1.walking\"..." type=io.containerd.differ.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.152117807Z" level=info msg="loading plugin \"io.containerd.event.v1.exchange\"..." type=io.containerd.event.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.152175060Z" level=info msg="loading plugin \"io.containerd.gc.v1.scheduler\"..." type=io.containerd.gc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.152311566Z" level=info msg="loading plugin \"io.containerd.service.v1.introspection-service\"..." type=io.containerd.service.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.152389195Z" level=info msg="loading plugin \"io.containerd.service.v1.containers-service\"..." type=io.containerd.service.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.152454323Z" level=info msg="loading plugin \"io.containerd.service.v1.content-service\"..." type=io.containerd.service.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.152514576Z" level=info msg="loading plugin \"io.containerd.service.v1.diff-service\"..." type=io.containerd.service.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.152579204Z" level=info msg="loading plugin \"io.containerd.service.v1.images-service\"..." type=io.containerd.service.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.152640957Z" level=info msg="loading plugin \"io.containerd.service.v1.leases-service\"..." type=io.containerd.service.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.152702960Z" level=info msg="loading plugin \"io.containerd.service.v1.namespaces-service\"..." type=io.containerd.service.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.152765088Z" level=info msg="loading plugin \"io.containerd.service.v1.snapshots-service\"..." type=io.containerd.service.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.152827466Z" level=info msg="loading plugin \"io.containerd.runtime.v1.linux\"..." type=io.containerd.runtime.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.153106979Z" level=info msg="loading plugin \"io.containerd.runtime.v2.task\"..." type=io.containerd.runtime.v2
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.153279363Z" level=info msg="loading plugin \"io.containerd.monitor.v1.cgroups\"..." type=io.containerd.monitor.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.154451794Z" level=info msg="loading plugin \"io.containerd.service.v1.tasks-service\"..." type=io.containerd.service.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.154593426Z" level=info msg="loading plugin \"io.containerd.grpc.v1.introspection\"..." type=io.containerd.grpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.154664179Z" level=info msg="loading plugin \"io.containerd.internal.v1.restart\"..." type=io.containerd.internal.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.154841188Z" level=info msg="loading plugin \"io.containerd.grpc.v1.containers\"..." type=io.containerd.grpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.154901940Z" level=info msg="loading plugin \"io.containerd.grpc.v1.content\"..." type=io.containerd.grpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.154963443Z" level=info msg="loading plugin \"io.containerd.grpc.v1.diff\"..." type=io.containerd.grpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155020446Z" level=info msg="loading plugin \"io.containerd.grpc.v1.events\"..." type=io.containerd.grpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155076699Z" level=info msg="loading plugin \"io.containerd.grpc.v1.healthcheck\"..." type=io.containerd.grpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155133327Z" level=info msg="loading plugin \"io.containerd.grpc.v1.images\"..." type=io.containerd.grpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155189079Z" level=info msg="loading plugin \"io.containerd.grpc.v1.leases\"..." type=io.containerd.grpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155250207Z" level=info msg="loading plugin \"io.containerd.grpc.v1.namespaces\"..." type=io.containerd.grpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155325461Z" level=info msg="loading plugin \"io.containerd.grpc.v1.snapshots\"..." type=io.containerd.grpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155387339Z" level=info msg="loading plugin \"io.containerd.grpc.v1.tasks\"..." type=io.containerd.grpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155480468Z" level=info msg="loading plugin \"io.containerd.grpc.v1.version\"..." type=io.containerd.grpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155545221Z" level=info msg="loading plugin \"io.containerd.tracing.processor.v1.otlp\"..." type=io.containerd.tracing.processor.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155615725Z" level=info msg="skip loading plugin \"io.containerd.tracing.processor.v1.otlp\"..." error="no OpenTelemetry endpoint: skip plugin" type=io.containerd.tracing.processor.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155693603Z" level=info msg="loading plugin \"io.containerd.internal.v1.tracing\"..." type=io.containerd.internal.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155767482Z" level=error msg="failed to initialize a tracing processor \"otlp\"" error="no OpenTelemetry endpoint: skip plugin"
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155890863Z" level=info msg="loading plugin \"io.containerd.ttrpc.v1.task\"..." type=io.containerd.ttrpc.v1
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.155973367Z" level=warning msg="failed to load plugin io.containerd.ttrpc.v1.task" error="no io.containerd.event.v1 plugins with id publisher: not found"
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.156624523Z" level=info msg=serving... address=/var/run/balena-engine/containerd/balena-engine-containerd-debug. Sock
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.156898661Z" level=info msg=serving... address=/var/run/balena-engine/containerd/balena-engine-containerd.sock.ttrpc
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.157136798Z" level=info msg=serving... address=/var/run/balena-engine/containerd/balena-engine-containerd.sock
May 16 07:47:16 36325ff balenad[844270]: time="2024-05-16T07:47:16.157229927Z" level=info msg="containerd successfully booted in 0.099308s"
May 16 07:47:16 36325ff balenad[844258]: time="2024-05-16T07:47:16.191754584Z" level=info msg="Storage migration skipped: %!s(<nil>)"
May 16 07:47:16 36325ff balenad[844258]: time="2024-05-16T07:47:16.223224844Z" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugin.moby
May 16 07:47:16 36325ff kernel: EXT4-fs error (device mmcblk2p6): ext4_lookup:1833: inode #1388564: comm balenad: deleted inode referenced: 1784793
May 16 07:47:16 36325ff balenad[844258]: time="2024-05-16T07:47:16.223345350Z" level=info msg="stopping healthcheck following graceful shutdown" module=libcontainerd
May 16 07:47:17 36325ff balenad[841924]: Parent process exited
May 16 07:47:17 36325ff balenad[844258]: failed to start daemon: error initializing graphdriver: lstat /var/lib/docker/overlay2/opaque-bug-check446572362: structure needs cleaning
May 16 07:47:17 36325ff systemd[1]: balena.service: Main process exited, code=exited, status=1/FAILURE
May 16 07:47:17 36325ff systemd[1]: balena.service: Failed with result 'exit-code'.
May 16 07:47:17 36325ff systemd[1]: Failed to start Balena Application Container Engine.
May 16 07:47:17 36325ff systemd[1]: balena.service: Start request repeated too quickly.
May 16 07:47:17 36325ff systemd[1]: balena-engine.socket: Failed with result 'service-start-limit-hit'
Shmulik
