balena os configure fails with "This service may not be available in the `us-east-1' region."
We have an Open Balena server running. I have configured balena CLI to use it in ~/.balenarc.yml.
If I want to configure an OS image, I run the following command, which fails:
$ balena os configure --debug --config-network ethernet --fleet admin/pts-cctv-chipsee-7inch-test test-img
[debug] new argv=[/home/tue/balena-cli/balena,/snapshot/balena-cli/bin/balena,os:configure,--config-network,ethernet,--fleet,admin/pts-cctv-chipsee-7inch-test,test-img] length=8
[debug] Deprecation check: 0.18098 days since last npm registry query for next major version release date.
[debug] Will not query the registry again until at least 7 days have passed.
[debug] Event tracking error: getaddrinfo ENOTFOUND data.balena.r2p.com
BalenaRequestError: Request error: Inaccessible host: `resin-production-img-cloudformation.s3.amazonaws.com' at port `undefined'. This service may not be available in the `us-east-1' region.
    at Object.<anonymous> (/snapshot/balena-cli/node_modules/balena-sdk/node_modules/balena-request/build/request.js:193:27)
    at Generator.next (<anonymous>)
    at fulfilled (/snapshot/balena-cli/node_modules/balena-sdk/node_modules/tslib/tslib.js)
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
https://www.balena.io/docs/reference/balena-cli/#support-faq-and-troubleshooting
This has worked previously, and as far as I know, nothing on the Open Balena server has changed.
The device is of the type “raspberrypicm4-ioboard”.
I am using balena CLI version 14.5.12.
Any good suggestions for getting this to work again are more than welcome.
Welcome back! The above host (resin-production-img-cloudformation.s3.amazonaws.com) seems to work as expected. This might very well be related to your network setup for open-balena server or network/server/service/region/data center outage from AWS end. The latter has been reported with similar errors multiple times. AWS provides a dashboard to get health reports of the services offered and the same is available at this link(https://status.aws.amazon.com/). API to access the services’ health is also available.
I would start with server network. Hope this helps. The SDK error message is misleading in the sense that it points to service not existing; but is more of reachability issue.
Thanks for the input. Looks like the nftables on our server got updated at one point, which caused the issue. We are up running again.
