So it’s been like 15 minutes now and it still hasn’t connected to my network. I have double-checked the credentials. Is it normal to take this long on a Pi Zero?
hi, it should connect sooner than 14 minutes. Can you confirm you have followed all the steps outlined here Get started on developing with Raspberry Pi 3 and Node.js - Balena Documentation regarding connection. Do you see the device in the dashboard ?
Figured it out. It is a regular Pi Zero without wifi. Bought it from a friend. Was a misunderstanding.
