Hallo!
When trying to do the first deploy to our openbalena instance, I get the following error:
$ balena deploy jetson_nano --debug
[debug] new argv=[/home/balena/balena-cli/balena,/snapshot/versioned-source/bin/balena,deploy,jetson_nano] length=4
[Debug] Parsing input…
[Debug] Loading project…
[Debug] Resolving project…
[Debug] docker-compose.yml file found at “/home/balena/mts_rtk_xavier”
[Debug] Creating project…
[Info] Everything is up to date (use --build to force a rebuild)
[Info] Creating release…
[Debug] Tagging images…
[Debug] Authorizing push…
[Info] Pushing images to registry…
Retrying “registry.balena.mydomain.ru/v2/4afbb05dc9f0e95cec14ae5d8d1d24ab:latest” after 2.00s (1 of 3) due to: Error: dial tcp xx.xx.xx.xx:443: connect: connection refused
Retrying “registry.balena.mydomain.ru/v2/d45a967893305de7c1a6d5d11ed1d87c:latest” after 2.00s (1 of 3) due to: Error: dial tcp xx.xx.xx.xx:443: connect: connection refused
Retrying “registry.balena.mydomain.ru/v2/32807fd06439c0757b5b83e6ec3b0cd7:latest” after
[Debug] Saving image registry.balena.mydomain.ru/v2/4afbb05dc9f0e95cec14ae5d8d1d24ab
[Debug] Untagging images…
[Info] Saving release…
[Error] Deploy failed
Balena is hidden behind NAT. xx.xx.xx.xx - external address.
I’m using registry v3.1.1 and CLI v12.30.2.
I wanted to clarify: can balena work through nat
