Project is abandoned, I’ll not be working on this project anymore.
if anyone ends up creating it please ping me. I’d love to see how they end up building it.
Background:
I’ve been following the developments of IPFS for the past 2-3ish years. and wanted to add it to one my future projects. Collecting sensor data from a bunch of raspberry pi’s, in a offline way. seemed like a good fit.
Why this project would be helpful?
Imaging your setting up a new fleet of 10x RPI4’s with temperature sensors, and you need a quick way to collect all the data from all the sensors streaming data in from the sensors. And you don’t feel like setting up a full scale database, or the complexities of a cloud database.
Ideally this would be as easy as adding something that looks like this to your docker file
Using balena blocks you can get a dashboard up and running very quickly, by connecting to a local or internet connected graphana dashboard. see web application
the issue i was facing was “ipfs” the npm package is not the same thing as the ipfs daemon! which needed to be installed seperatily ARG! not super clear…
Will be following this!
We want to accomplish something like this in the future, where Raspberry Pi’s or Arduino’s are collecting telemetry from sensors / GPIO’s and sending it to a “hub” device, which collects all this data in a secure way. But not via the internet, but something like LoRaWAN, because not every device is capable of getting a decent WiFi / Ethernet connection. Is this something that you’re trying to do or is this via a local WiFi / Ethernet network provided by the Pi?
This project targets devices attached to hub devices vs multiple devices attached to one hub.
Within the network exists
temp sensor <-wires-> Arduino uno ← serial cable-> rpi4 + balena blocks
| connection over database software like orbis db.
V temp sensor <-wires->Arduino uno <- serial cable-> rpi4 +balena blocks
pictured above has all the sensor connected over a radio EX: LoRaWan, zibee etc.. to one hub device. this project is designed to make colating multiple pi’s sensors easy.
where the sensors are directly attached to the pi’s
Related topic talk:
I absolutely think there is a space for way to connect embedded internet connected devices directly to Balena. I have heard of a project that attempts to do this by using a hub device as a gateway. from what I heard that project turned out to be really complicated!
I’d love to see a way to push code as easy as balena but using something like the ESP32 or something in that class of boards.
We’re trailing similar paths @wisehackermonkey. We’ve been testing out IPFS for creating ditributed data repositories.
We’re currently stuck at having different IPFS instances discover each other on the local network. I’ve found this example of using avahi with Balena, but we haven’t gotten it working yet. Here’s how I’m trying to do it, but with SSB (Secure Scuttlebutt):
Maybe @mpous has some tips on doing this the right way.
