I want to run Balena OS and Balena Dash with RPiZero no wifi. I see in the code have wifi-connect, how to modify it to use LAN via USB only?
You can find on how to setup your piZero as a Ethernet gadget here https://learn.adafruit.com/turning-your-raspberry-pi-zero-into-a-usb-gadget/ethernet-gadget
I’ve not heard of people doing this with balenaOS, but I don’t see why it wouldn’t work in theory. I’d give it a go myself, however I don’t have the hardware with me.
Maybe @chrisys has tried this before?
@thanh_tan this should be as simple as adding the USB LAN adapter - wifi-connect doesn’t do anything if there is an active connection. If you do want to remove it you can remove that block from the docker-compose.yml file and delete the wifi-connect folder, the rest of the project will work find without it. I hope this helps!
