Slowly working myself through the initial Balena Cloud experience. Currently working with two fleets one for ARM V6 devices (Pi Zero W) and another one for ARM V8 (e.g. PI 4 and CM4 devices).
Have built some basic infrastructure in Python 3.10 and been playing with both fleets in parallel.
So far so good.
Now I am adding a few REST endpoints and other services requireing aiohttp. Very simple and small for now.
All works well locally on an M1 Mac as well as on the ARM V8 fleet. However the builds for AMR V6 started failing the moment I added aiohttp to requirements.txt. Tried to run builds with the -c flag (to skip cache) but no change.
When I remove aiohttp from my pip install list, the build is successful on ARM V6.
Here is the build error:
[main] creating build/temp.linux-armv6l-3.10
[main] creating build/temp.linux-armv6l-3.10/aiohttp
[main] gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC -I/usr/local/include/python3.10 -c aiohttp/_websocket.c -o build/temp.linux-armv6l-3.10/aiohttp/_websocket.o
[main] error: command 'gcc' failed: No such file or directory
[main] ----------------------------------------
[main]
[main] ERROR: Failed building wheel for aiohttp
Your help would be much appreciated!
