Hey team,
When I was trying to log in on the cli via web authorization. I got the following error:
PS C:\Windows\system32> balena -v
11.35.16
PS C:\Windows\system32> balena login
_ _
| |__ __ _ | | ____ _ __ __ _
| '_ \ / _` || | / __ \| '_ \ / _` |
| |_) | (_) || || ___/| | | || (_) |
|_.__/ \__,_||_| \____/|_| |_| \__,_|
Logging in to balena-cloud.com
? How would you like to login? Web authorization (recommended)
Opening web browser for URL:
https://dashboard.balena-cloud.com/login/cli/http%253A%252F%252F127.0.0.1%253A8989%252Fauth
Error: listen EACCES: permission denied 0.0.0.0:8989
at Server.setupListenHandle [as _listen2] (net.js:1263:19)
at listenInCluster (net.js:1328:12)
at Server.listen (net.js:1415:7)
at Function.listen (C:\Program Files\balena-cli\client\node_modules\express\lib\application.js:618:24)
at createServer (C:\Program Files\balena-cli\client\build\auth\server.js:17:24)
at Object.exports.awaitForToken (C:\Program Files\balena-cli\client\build\auth\server.js:27:29)
at Object.exports.login (C:\Program Files\balena-cli\client\build\auth\index.js:21:21)
As seen above this is version 11.35.16. I was able to log in via credentials but I wanted to report the bug. This is using the installer version: balena-cli-v11.35.16-windows-x64-installer.exe
-Thomas
