Hello everyone.
I have a powershell script which is fetching balena cloud details of my fleet frequent so I connect via API Token to balena which worked nice till yesturday.?
Checking today in more detail I still can not auth any longer via CLI (Windows - on two dedicated systems where one was fresh installed)
I get error:
Logging in to balena-cloud.com
Token authentication failed
UNABLE_TO_VERIFY_LEAF_SIGNATURE: request to https://api.balena-cloud.com/actor/v1/whoami failed, reason: unable to verify the first certificate
Tried it via web auth and credentials too for “balena login” but here the webbrowser give me a “something went wrong” back or same issue with the certificate.
I wanted to see if I can fetch the used cert from api.balena.cloud to see if my system has issues with its cert store but this is as well giving me an error so I suspect the API might really have issues?
root@Server-01:~# openssl s_client -showcerts -servername server -connect api.balena-cloud.com:443
CONNECTED(00000003)
80FBDEB4A67F0000:error:0A000410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure:../ssl/record/rec_layer_s3.c:1584:SSL alert number 40
no peer certificate available
No client certificate CA names sent
SSL handshake has read 7 bytes and written 308 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
Checked the official status page from balena (nothing to spot for my issue).
Running a bit out of ideas without beeing able to raise a payed support ticket which I do not have in my current plan so can you confirm CLI login or API work is working for you or you had simular you fixed in the past?
Thanks for any hint and best,
Richie
