Balena CLI suddenly fail: "The requested image's platform (linux/amd64) does not match the detected host platform"
Here’s another failing Dockerfile (stripped down from my original but still failing). I had previously been using golang:1.15, but getting this error made me upgrade. Unfortunately, there’s still an error.
FROM --platform=linux/arm64 balenalib/raspberrypi4-64-golang:1.19 as builder
RUN go install -v github.com/mozz100/tohora@v0.3.2
FROM  bh.cr/balenalabs/browser-aarch64
RUN install_packages cec-utils
COPY --from=builder /go/bin/tohora /home/chromium/tohora
Here is how the logs end:
[Info] Uploading images
[Success] Successfully uploaded images
[Error] Some services failed to build:
[Error] Service: kiosk
[Error] Error: failed to get destination image “sha256:3d5a94136dbf7f4a051c26c37fc56d644152b80809daf306cae51c95be20c272”: image with reference sha256:3d5a94136dbf7f4a051c26c37fc56d644152b80809daf306cae51c95be20c272 was found but does not match the specified platform: wanted linux/arm64/v8, actual: linux/amd64
[Info] Built on arm01
[Error] Not deploying release.
Remote build failed
