After login on balena with credentials :
$balena devices
ID UUID DEVICE NAME DEVICE TYPE APPLICATION NAME STATUS IS ONLINE SUPERVISOR VERSION OS VERSION DASHBOARD URL
1 438d87b divine-sun raspberrypi3 myApp Idle false 8.0.0 balenaOS 2.26.0+rev1
I can run docker without sudo on mac os but still command balena build -a myApp -h 192.168.0.110 -p 2375 . prints
Docker seems to be unavailable. Is it installed and running?
If you need help, don't hesitate in contacting us at:
GitHub: https://github.com/balena-io/balena-cli/issues/new
Forums: https://forums.balena.io
I know this topic was resolved some time ago, so sorry to anyone that gets notified. However, I came across this when trying to solve the same problem. We were trying to use balena deploy on CircleCI however kept getting “Docker seems unavailable”.
In the end we looked at the Balena CLI source where the docker parameters are defined. We had to specifically provide the host, port and certificate paths.
