I thought this might come in handy for other people who are trying to download balena OS disk images, configure and preload them on GitHub actions and are getting the error “AUFS not found” or similar (which applies for earlier raspberry pi models and some other devices which haven’t been transitioned to the overlay - see here for a list).
This action uses Ubuntu 18.04 base and allows you to install and configure AUFS as well as the balena CLI tool and then use it to configure and preload an image. I’ve removed some parts (strategy matrix part and some other application specific env variables so just the necessary stuff for AUFS is left).
Hope this might be helpful to someone in the future…
name: BalenaCloud Create Image (RasPi)
on:
schedule:
- cron: "0 0 * * 0" # Run weekly
workflow_dispatch:
env:
balena-cli: v12.55.4
jobs:
raspi:
runs-on: ubuntu-18.04
steps:
- name: Checkout
uses: actions/checkout@v2
- name: Install latest balena-cli
run: |
sudo apt-get update
sudo apt-get install -y curl unzip zip lxc libarchive-tools aufs-tools
sudo modprobe aufs
cd /opt/
echo "Uses Balena CLI version: ${{ env.balena-cli }}"
cat /etc/docker/daemon.json
echo "$(grep aufs /proc/filesystems)"
echo "$(docker info)"
curl -O -sSL "https://github.com/balena-io/balena-cli/releases/download/${{ env.balena-cli }}/balena-cli-${{ env.balena-cli }}-linux-x64-standalone.zip"
unzip balena-cli-*-linux-x64-standalone.zip
sudo ln -s /opt/balena-cli/balena /usr/bin/
cd ~
- name: Balena login
run: balena login --token ${{ secrets.BALENA_API_TOKEN }} > /dev/null
- name: Download OS image
run: balena os download "${{ matrix.baseos }}" -o balena-base.img --version "${{ env.BALENA_OS_VERSION }}" --debug
- name: Configure image
run: balena os configure balena-base.img --fleet "nebraltd/${{ env.FLEET_NAME }}" --config-network ethernet --version "${{ env.BALENA_OS_VERSION }}" --debug
- name: Preload image
run: balena preload balena-base.img --fleet nebraltd/"${{ env.FLEET_NAME }}" --pin-device-to-release -c current --debug
