Anyone been able to get PiVPN working on balena? Or do you just use resin vpn for accessing your network away from home? If you use resin, how do you set it up (e.g. creating users, certs, etc.)?Tweakbox Appvalley
Hi there, welcome to the forums!
The balena VPN service is used internally in many services, for example SSH access or public urls. You can’t manage it though (create users, certs, etc).
You can definitely go with your own vpn solution alongside if that is something that you require. I could not find anything specific to balena about PiVPN, but this repository seems like a good starting point: https://github.com/ljishen/pivpn-docker. It should be straightforward to setup.
