Hey!
I’m running Resin on a RaspberryPi3. I have the same image commit running on many devices (>10). The CPU was getting very slow in some devices, so I debug it using htop. Thats when I saw that there was a process consuming almost 80% of the CPU time and the 4 cores were almost at 98% each when normally they should be at 70% top. That process was atd.
So I run atq to see the jobs running and there were a lot of strange jobs running. I removed a bunch of them using atrm jobID and the CPU rested. To see what the Jobs were I used at -c jobID and it seems to be some Resin stuff. The weird thing again is that all jobs throw the same output.
An example of what I got:
root@94e7c0d:/usr/src/app# atq
68 Wed Nov 22 10:00:00 2017 a root
21 Wed Nov 22 09:00:00 2017 a root
64 Wed Nov 22 10:00:00 2017 a root
26 Wed Nov 22 10:00:00 2017 a root
27 Wed Nov 22 09:00:00 2017 a root
72 Wed Nov 22 10:00:00 2017 a root
74 Wed Nov 22 10:00:00 2017 a root
35 Wed Nov 22 09:00:00 2017 a root
78 Wed Nov 22 10:00:00 2017 a root
52 Wed Nov 22 10:00:00 2017 a root
51 Wed Nov 22 09:00:00 2017 a root
47 Wed Nov 22 09:00:00 2017 a root
61 Wed Nov 22 09:00:00 2017 a root
29 Wed Nov 22 09:00:00 2017 a root
41 Wed Nov 22 09:00:00 2017 a root
46 Wed Nov 22 10:00:00 2017 a root
54 Wed Nov 22 10:00:00 2017 a root
20 Wed Nov 22 10:00:00 2017 a root
50 Wed Nov 22 10:00:00 2017 a root
58 Wed Nov 22 10:00:00 2017 a root
80 Wed Nov 22 10:00:00 2017 a root
19 Wed Nov 22 09:00:00 2017 a root
18 Wed Nov 22 10:00:00 2017 a root
76 Wed Nov 22 10:00:00 2017 a root
30 Wed Nov 22 10:00:00 2017 a root
38 Wed Nov 22 10:00:00 2017 a root
75 Wed Nov 22 09:00:00 2017 a root
66 Wed Nov 22 10:00:00 2017 a root
10 Wed Nov 22 10:00:00 2017 a root
13 Wed Nov 22 09:00:00 2017 a root
15 Wed Nov 22 09:00:00 2017 a root
53 Wed Nov 22 09:00:00 2017 a root
60 Wed Nov 22 10:00:00 2017 a root
48 Wed Nov 22 10:00:00 2017 a root
28 Wed Nov 22 10:00:00 2017 a root
57 Wed Nov 22 09:00:00 2017 a root
11 Wed Nov 22 09:00:00 2017 a root
12 Wed Nov 22 10:00:00 2017 a root
43 Wed Nov 22 09:00:00 2017 a root
17 Wed Nov 22 09:00:00 2017 a root
39 Wed Nov 22 09:00:00 2017 a root
25 Wed Nov 22 09:00:00 2017 a root
24 Wed Nov 22 10:00:00 2017 a root
69 Wed Nov 22 09:00:00 2017 a root
31 Wed Nov 22 09:00:00 2017 a root
70 Wed Nov 22 10:00:00 2017 a root
67 Wed Nov 22 09:00:00 2017 a root
65 Wed Nov 22 09:00:00 2017 a root
42 Wed Nov 22 10:00:00 2017 a root
71 Wed Nov 22 09:00:00 2017 a root
40 Wed Nov 22 10:00:00 2017 a root
34 Wed Nov 22 10:00:00 2017 a root
56 Wed Nov 22 10:00:00 2017 a root
77 Wed Nov 22 09:00:00 2017 a root
45 Wed Nov 22 09:00:00 2017 a root
79 Wed Nov 22 09:00:00 2017 a root
44 Wed Nov 22 10:00:00 2017 a root
62 Wed Nov 22 10:00:00 2017 a root
37 Wed Nov 22 09:00:00 2017 a root
16 Wed Nov 22 10:00:00 2017 a root
63 Wed Nov 22 09:00:00 2017 a root
59 Wed Nov 22 09:00:00 2017 a root
32 Wed Nov 22 10:00:00 2017 a root
23 Wed Nov 22 09:00:00 2017 a root
22 Wed Nov 22 10:00:00 2017 a root
36 Wed Nov 22 10:00:00 2017 a root
root@94e7c0d:/usr/src/app# at -c 11
#!/bin/sh
# atrun uid=0 gid=0
# mail root 0
umask 22
NODE_VERSION=6.9.1; export NODE_VERSION
TIMEZONE=America/Los_Angeles; export TIMEZONE
RESIN_SUPERVISOR_API_KEY=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx; export RESIN_SUPERVISOR_API_KEY
OPERATION_START_HOUR=0900; export OPERATION_START_HOUR
HOSTNAME=94e7c0d; export HOSTNAME
RESIN_APP_ID=538246; export RESIN_APP_ID
BASE_REPO=cristian-nvidia-net-basic-kiwibot_real_local_3-0.0.3; export BASE_REPO
RESIN=1; export RESIN
RESIN_DEVICE_TYPE=raspberrypi3; export RESIN_DEVICE_TYPE
RESIN_SUPERVISOR_ADDRESS=http://127.0.0.1:48484; export RESIN_SUPERVISOR_ADDRESS
RESIN_WIFI_CONNECT_VERSION=2.0.7; export RESIN_WIFI_CONNECT_VERSION
USER=root; export USER
RESIN_SUPERVISOR_HOST=127.0.0.1; export RESIN_SUPERVISOR_HOST
RESIN_DEVICE_UUID=xxxxxxxxxxxxxxxxxxxxx; export RESIN_DEVICE_UUID
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin; export PATH
RESIN_API_KEY=xxxxxxxxxxxxxxxxxxxxxxxx; export RESIN_API_KEY
PWD=/usr/src/app; export PWD
RESIN_SUPERVISOR_VERSION=6.1.3; export RESIN_SUPERVISOR_VERSION
RESIN_APP_RELEASE=xxxxxxxxxxxxxxxxxxxxxxxxxx; export RESIN_APP_RELEASE
RESIN_APP_NAME=Staging; export RESIN_APP_NAME
ROS_HOSTNAME=localhost; export ROS_HOSTNAME
RESIN_DEVICE_NAME_AT_INIT=kiwibot1; export RESIN_DEVICE_NAME_AT_INIT
OPERATION_FINISH_HOUR=1000; export OPERATION_FINISH_HOUR
SHLVL=1; export SHLVL
HOME=/root; export HOME
DEVICE_TYPE=raspberrypi3; export DEVICE_TYPE
RESIN_HOST_OS_VERSION=Resin\ OS\ 2.3.0+rev1; export RESIN_HOST_OS_VERSION
SOUNDS_URL=xxxxxxxxx; export SOUNDS_URL
SERVER_URL=xxxxxxxxxx; export SERVER_URL
DBUS_SYSTEM_BUS_ADDRESS=unix:path=/host/run/dbus/system_bus_socket; export DBUS_SYSTEM_BUS_ADDRESS
KIWIBOT_ID=1; export KIWIBOT_ID
RESIN_SUPERVISOR_PORT=48484; export RESIN_SUPERVISOR_PORT
cd /usr/src/app || {
echo 'Execution directory inaccessible' >&2
exit 1
#! /bin/bash
# This script will run at OPERATION_START_HOUR and at OPERATION_FINISH_HOUR. It will update the update lock for resin
# If the robot is in operational hours, prevent the robot to update
LOG_ROUTE=/data/updates-lock.log
LOCK_FILE_ROUTE=/tmp/resin/resin-updates.lock
CURRENT_HOUR="$(date +%H%M)"
if [ ${CURRENT_HOUR} -ge "${OPERATION_START_HOUR}" ] && [ ${CURRENT_HOUR} -lt "${OPERATION_FINISH_HOUR}" ]; then
echo "$(date) OPERATIONAL HOURS, WILL NOT UPDATE" >> ${LOG_ROUTE}
if [ ! -f ${LOCK_FILE_ROUTE} ]; then
echo "$(date) CREATING resin-updates.lock" >> ${LOG_ROUTE}
touch ${LOCK_FILE_ROUTE}
fi
else
echo "$(date) OUT OF OPERATIONAL HOURS. WILL UPDATE IF UPDATE IS AVAILABLE" >> ${LOG_ROUTE}
if [ -f ${LOCK_FILE_ROUTE} ]; then
echo "$(date) REMOVING resin-updates.lock" >> ${LOG_ROUTE}
rm ${LOCK_FILE_ROUTE}
fi
fi
All jobs output the same… Any idea whats happening? Why are so many jobs running and why is a random thing and not happen in all devices??
Thanks in advice!!
