Dear all,
I’m facing a problem with my ARTIK520.
After upgrading from version 1.24, the bluetooth doesn’t work anymore.
Is there a new version of resinOS who solve this issue?
Thank you very much.
Dear all,
Thank you. We are aware of the issue and a new version of resinOS for the ARTIK520 will be released soon, with a fix for bluetooth.
Thank you Afitzek,
could you please tell me the release date?
It was released just a couple of minutes ago (2.0.8+rev1).
Thank you very much!
Hi Afitzek,
I installed the new version of resinOS on my ARTIK 520, but I still have problem with the bluetooth.
I installed bluez because I didn’t find the bluetooth service inside the "default"2.0.8 resinOS version.
I executed the following commands:
# agent on
# default-agent
and
# scan on
The result is:
No default controller available
Am I doing something wrong?
Can you also install rfkill and issue a “rfkill list”? And if bluetooth shows as soft blocked, can you do a “rfkill unblock bluetooth” and try again?
Hi! I found that:
root@2b4b970-2b4b970:/usr/src/app# rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: brcmfmac-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
2: bcm4354 Bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
then
root@2b4b970-2b4b970:/usr/src/app# rfkill unblock bluetooth
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: no
I restarted the bluetooth service, and repeat the bluetoothctl commands,but the result is still the same.
after rebooting ARTIK, the status of the bluetooth service is as follows:
root@2b4b970-2b4b970:/usr/src/app# systemctl status bluetooth.service -l
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
Active: active (running) since Fri 2017-07-07 09:27:30 UTC; 1min 57s ago
Docs: man:bluetoothd(8)
Main PID: 151 (bluetoothd)
Status: "Running"
CGroup: /docker/b181d9339d5b880211b8f78b3a143d5e42bcd1f87848ec2080d3d1407ef8ed48/system.slice/bluetooth.service
└─151 /usr/lib/bluetooth/bluetoothd
Jul 07 09:27:29 2b4b970-2b4b970 bluetoothd[151]: l2cap_bind: Address already inuse (98)
Jul 07 09:27:29 2b4b970-2b4b970 bluetoothd[151]: network-nap: Invalid argument (22)
Jul 07 09:27:29 2b4b970-2b4b970 bluetoothd[151]: avrcp-controller: Protocol notsupported (93)
Jul 07 09:27:29 2b4b970-2b4b970 bluetoothd[151]: audio-avrcp-target: Protocol not supported (93)
Jul 07 09:27:29 2b4b970-2b4b970 bluetoothd[151]: Sap driver initialization failed.
Jul 07 09:27:29 2b4b970-2b4b970 bluetoothd[151]: sap-server: Operation not permitted (1)
Jul 07 09:27:29 2b4b970-2b4b970 bluetoothd[151]: hci0 Load Connection Parameters failed: Unknown Command (0x01)
Jul 07 09:27:30 2b4b970-2b4b970 systemd[1]: Started Bluetooth service.
Let me look at it on my side too and come back to you.
Do you have a -dev image so you can access the host OS on the serial debug connection?
No, But I saw that the -dev version of the 2.0.8 is available.
I have to download it and flash it.
What are you looking for?
Can you install the .dev variant please?
On my end I seem to have bluetooth working on the host OS side. I would like to verify on your machine a few things once you have the -dev variant installed and you are connected on the serial debug connection to the host OS.
Hi!
I installed the .dev version and connected the device through the serial debug.
Which are the next steps?
What does “systemctl status brcm-bt-firmware.service -l” say?
Think I found it. Created a PR here: https://github.com/resin-os/meta-artik/pull/24
Thank you, but now what I have to do?
Wait for another release
I hope to have the 2.0.9 done sometimes on Monday
Hi @samsung.test0 we have released version v2.0.8+rev2 which should fix the bluetooth issue you reported.
Hi @floion, I’m downloading it.
Thank you!
