airplay is audio out of sync
the log showing
airplay  warning: could not acquire a Shairport Sync native D-Bus interface "org.gnome.ShairportSync.i14" on the system bus.
 airplay  warning: could not acquire an MPRIS interface named "org.mpris.MediaPlayer2.ShairportSync.i14" on the system bus.
I’ve already disable BT and Spotify and also set to Standalone mode (no multi-room)
Hello @tdb32 first of all welcome to the balena community!
Could you please confirm what hardware are you using?
Did you try to reboot the device? Does it work after reboot?
